[GRASS-dev] GSoC 2016 - PyQt GRASS - Report 10
Hi all!
Here is the tenth report of my GSoC project - PyQt based GUI of GRASS automatically generated from XML. For screenshots and other stuff see its wiki: https://trac.osgeo.org/grass/wiki/GSoC/2016/PyQtGUI
What did you get done this week?
  • New widgets: Mapsets, locations and dbtable (created dependencies between those), special widget for quiet/normal/verbose module output
  • Created definitive (I hope) size policy. ialog width and height still depends on content volume, but now just till some limit. After that, the tab gets sliders to scroll.
  • Fixes and updates: Widgets Columns and Layers now work with map in widget ‘map’ when ‘input’ does not exist; fix widget Colors for default value in ‘r:g:b’ style
  • Main window and dialogs now have grass logo and icon
  • Required widget is highlighted by red star
  • Tab ‘required’ isn’t visible when it’s empty
  • Was created documentation for .py files and for individual class, methods…
  • key_desc used instead of type (when showing widget name)
  • Big refactoring using default pep8
What do you plan on doing next week?
  • I’m sorry but I will be now for two weeks (as I said at the beginning) off. Off the internet, off the computer. I hope that I can can turn for one day to civilization and work. I have unfinished one widget (icons choosing in d.vect) and I hope that I will be able to work little bit next week and finish it…
Have a nice week,
Ondrej
