[GRASS-dev] GSoC 2016 - PyQt GRASS - Report 7
Hi all!
Here is the seventh report of my GSoC project - PyQt based GUI of GRASS automatically generated from XML. For screenshots and other stuff see its wiki: https://trac.osgeo.org/grass/wiki/GSoC/2016/PyQtGUI
What did you get done this week?
  • New widgets: cats, multiple values, raster_3d
  • Little changes in other widgets: Mapset is not selectable in treewidget, flags and default widget were moved into its own classes
  • If widgets have both label and description, description is used as help/tooltip
  • Massive refactoring of code for command (running, changing dictionary, changing cmd string that user see)
What do you plan on doing next week?
  • I want to start coding the widges with dependencies (column, layer); I will also check my code with pep8
Are you blocked on anything?
  • I was blocked for some while on the refactoring, but it’s OK now
Have a sunny weekend!
Ondrej
