Hi all!
Here is the eigth report of my GSoC project - PyQt based GUI of GRASS automatically generated from XML. For screenshots and other stuff see its wiki: https://trac.osgeo.org/grass/wiki/GSoC/2016/PyQtGUI
What did you get done this week?
New widgets: layer, columns, multiple values with values_desc, separator, group, colors
helpButton and closeButton work
Help/tooltip also for flags
Fix: Float or int equals 0 → delete from cmd, more flags than one will not call overwrite, set minimum size to browsebutton
Refactoring (using methods as callbacks)
What do you plan on doing next week?
- DB widgets with dependencies
Are you blocked on anything?
- Nope
Thank you and have a real cool time!
Ondrej
