[GRASS-dev] GSOC 2018 project for GRASS GIS
My name is Sanjeet Bhatti and I am an MSc. student in Computer Science
from University of Saskatchewan, Canada. I was going through the list
of GSOC project ideas of GRASS GIS and I found one that caught my
interest: "Full support of Python 3 in GRASS GIS".
I am familiar with python programming as well as have a basic
understanding of wxPython. Currently, I am setting up my development
environment by checking out the development branch (trunk) of GRASS 7
available at this link[0].
Are there any initial tasks that I should be doing apart from listing
the generally used solutions for migrating from Python 2 to 3? And,
where do I need to submit these?
Thank you,
Sanjeet
[0] svn.osgeo.org/grass/grass/
Hi Sanjeet,
On Tue, Feb 27, 2018 at 3:08 AM, Sanjeet <edu.sanjeet@gmail.com> wrote:
That's great and for sure an important topic to work on!
There are some tickets flagged with "python3":
https://trac.osgeo.org/grass/query?status=!closed&keywords=~python3
I suppose that more tickets should carry that keyword but they need to
be identified by scanning those with "python" keyword.
The topic suggestions are posted here (as you know):
https://trac.osgeo.org/grass/wiki/GSoC/2018
but did you already check this page?
https://wiki.osgeo.org/wiki/Google_Summer_of_Code_Recommendations_for_Students
Best
Thank you,
Sanjeet
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
On Wed, Feb 28, 2018 at 3:38 PM, Markus Neteler <neteler@osgeo.org> wrote:
Hi Sanjeet,
interest: “Full support of Python 3 in GRASS GIS”.
That’s great and for sure an important topic to work on!
There are some tickets flagged with “python3”:
What is the policy about the python shebang explained in python PEP 394
https://www.python.org/dev/peps/pep-0394/
In order to tolerate differences across platforms, all new code that needs to invoke the Python interpreter should not specify python, but rather should specify either python2 or python3 (or the more specific python2.x and python3.x versions; see the Migration Notes). This distinction should be made in shebangs, when invoking from a shell script, when invoking via the system() call, or when invoking in any other context.
… unless scripts are deliberately written to be source compatible with both Python 2.x and 3.x
Currently packagers replace python with python2 in the shebang of GRASS scripts.
Markus M
be identified by scanning those with “python” keyword.
Best
Thank you,
Sanjeet
Hi Sanjeet,
On Mon, Feb 26, 2018 at 9:08 PM, Sanjeet <edu.sanjeet@gmail.com> wrote:
I would leave that up to you, you can send it in email, post it on
your github or whatever seems convenient for you.
Regarding the GUI, you can look at this ticket:
https://trac.osgeo.org/grass/ticket/3510
Basically, the GUI is mostly ported to work with wxPython4 (phoenix),
which is (unlike wxpython 3) Python 3 ready. So far we are running the
GUI on Python 2.7 only. There are some loose ends and depreciation
warnings, which would be nice to get rid of. Since we need to keep
backwards compatibility with wxpython 3, we wrapped some GUI classes
(gui/wxpython/gui_core/wrap.py), so you can start there. You need to
test your changes under both wxpython 3 and 4. Let me know if you need
more clarification. More info what is Attribute Table manager:
https://grass.osgeo.org/grass75/manuals/wxGUI.dbmgr.html
https://grasswiki.osgeo.org/wiki/WxGUI_Attribute_Table_Manager
To post a patch in that ticket, you need to get osgeo id:
https://www.osgeo.org/community/getting-started-osgeo/osgeo_userid/
Best,
Anna
Thank you,
Sanjeet
Hi Markus,
Thanks for sharing the links. I've gone through them now.
Sanjeet Bhatti
On Sat, Mar 3, 2018 at 10:50 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
Hi Sanjeet,
Hi Anna,
I will share the list soon.
Meanwhile, I've setup my development environment and compiled the
source code. I did not see the warning messages when I opened the
Attribution Table Manager as mentioned in the ticket #3510 even when I
installed wxpython 4 (on system Ubuntu 16.04 with Python 2.7.x).
Is it supposed to be displaying in the console? Because I did not get
any warnings.
I even tried to set the g.gisenv set="DEBUG=5" to print the debugging
messages along with WX_DEBUG. Am I missing some step?
Thanks
Sanjeet Bhatti
Hi Sanjeet,
Hi Anna,
any warnings.
Look in the GUI console (second tab at the bottom in Layer Manager).
You can check if you are indeed running wxpython 4 easily from GUI, go
to Python tab and try:
import wx
wx.version()
4.0.1 gtk2 (phoenix)
I would recommend running it in virtualenv.
Thanks
Sanjeet Bhatti
On Mon, Mar 5, 2018 at 6:43 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
import wx
wx.version()
Yes, I see them now. Thanks!
Sanjeet Bhatti
Hi Anna,
I've created a patch file for the ticket #3510.
I'm waiting for 'mantra' to create the osgeo user id, so that I can
upload the patch file.
Sanjeet Bhatti
Hi Anna,
What's your username?
Margherita Di Leo
Sanjeet,
Spotted this the other day if it helps.
https://medium.com/@boxed/moving-a-large-and-old-codebase-to-python3-33a5a13f8c99
Doug
On Tue, Mar 6, 2018 at 4:38 AM, Margherita Di Leo <diregola@gmail.com> wrote:
Hi Anna,
I’ve created a patch file for the ticket #3510.
I’m waiting for ‘mantra’ to create the osgeo user id, so that I can
What’s your username?
Margherita Di Leo
Doug Newcomb
USFWS
551F Pylon Dr
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb@fws.gov
__NOTE: This email correspondence and any attachments to and from this sender is subject to the Freedom of Information Act (FOIA) and may be disclosed to third parties.__​
wrote:
Hi Anna,
Hi Margherita,
I got the email from osgeo and I was able to proceed further and create id.
So, my osgeo userid is 'sanjeet'. Is this the username that you were
referring to?
Thanks
On Mar 6, 2018 11:26 AM, "Newcomb, Doug" <doug_newcomb@fws.gov> wrote:
Sanjeet,
33a5a13f8c99
Hi Doug,
Thank you so much for sharing that. It is going to be really helpful in
listing the steps to port to python 3.
Sanjeet
