[GRASS-dev] ​GSoC 2018 report week 01 - GRASS GIS module for Sentinel-2 cloud and shadow detection
Hi all!
I’m Roberta Fagandini and I’m working on my GSoC project, a GRASS GIS module for Sentinel-2 cloud and shadow detection.
This is my report for the first week of coding.
Since my progress has been a bit faster than expected I have already discussed with my mentors about further additions to the project. Therefore I have already updated my wiki page [0] changing the timeline. In this way, I will be able to release a more complete module.
1) What did I complete this week?
  • Checked the prototype version of the algorithm for cloud and shadow detection
  • Tested it
  • I better studied the documentation of the GRASS Python Scripting Library and started coding the GRASS python script following the workflow schema prepared during the bonding period [1]
  • Coded the ‘data preparation’ phase
  • Coded the clouds detection procedure
  • Added this first part of python script to my GitHub repository [2]
  • Discussed with my mentors about further additions
  • Discussed with the community about testing phase. I received some feedback and some developers stepped forward to help me in testing the algorithm
  • Shared progress with the community
Unfortunately, I wasn’t able to code on Thursday because of a PhD meeting with my supervisor.
2) What am I going to achieve for next week?
  • Finish the translation of the algorithm in a basic python script adding the shadows detection procedure and the steps for checking and cleaning the final outputs (see [1] for details)
  • Improve the python script so as to have a “light” working python script (manage temporary file, clean up the code, etc.)
  • Test it and fix bugs
  • Start implementing the GUI
3) Is there any blocking issue?
No at the moment.
Best wishes,
Roberta
[0] https://trac.osgeo.org/grass/wiki/GSoC/2018/CloudsAndShadowsDetection
[1] https://drive.google.com/file/d/1KYEKvNBurBFHw1xUTLjM0PW80Z-7br81/view?usp=sharing
[2] https://github.com/RobiFag/GRASS_clouds_and_shadows
Ciao Roberta,
Thanks for the comprehensive report!
One general hint: Even if the drawback is complex expression(s) I would suggest merging r.mapcalc calls. That can improve performance quite a bit (less data read and written) and reduces the need to manage temporary data.
See also: https://grass.osgeo.org/grass74/manuals/r.mapcalc.html#multiple-computations
If you don’t need the first_… To fifth_… files later, I would even say everything in 3rd_procedure.py until r.to.vect could be solved in a single mapcalc operation…
Kind regards and again thank for your GSoC work,
Stefan
From: grass-dev grass-dev-bounces@lists.osgeo.org on behalf of Roberta Fagandini robifagandini@gmail.com
Sent: Sunday, May 20, 2018 4:33:57 PM
To: soc@lists.osgeo.org; GRASS developers list
Subject: [GRASS-dev] ​GSoC 2018 report week 01 - GRASS GIS module for Sentinel-2 cloud and shadow detection
Hi all!
  • Tested it
No at the moment.
Best wishes,
Roberta
Ciao Stefan!
2018-05-20 21:44 GMT+02:00 Stefan Blumentrath <Stefan.Blumentrath@nina.no>:
Ciao Roberta,
Thank you so much for your hints! I’m trying to clean up the code without creating a too complex expression…I hope to share the new version by this evening or tomorrow at the latest.
Stefan
Thanks again!!
Roberta
From: grass-dev <grass-dev-bounces@lists.osgeo.org> on behalf of Roberta Fagandini <robifagandini@gmail.com>
Hi all!
  • Tested it
No at the moment.
Best wishes,
Roberta
