[GRASS-dev] ​GSoC 2018 report week 01 - GRASS GIS module for Sentinel-2 cloud and shadow detection
Hi all!
I have just added a new version of the grass python script to my GitHub repository [0].
I tried to clean up the code.
As always, any feedback is welcome!
Thanks in advance!
Roberta
[0] https://github.com/RobiFag/GRASS_clouds_and_shadows
2018-05-21 15:19 GMT+02:00 Roberta Fagandini <robifagandini@gmail.com>:
Ciao Stefan!
2018-05-20 21:44 GMT+02:00 Stefan Blumentrath <Stefan.Blumentrath@nina.no>:
Ciao Roberta,
Thanks for the comprehensive report!
One general hint: Even if the drawback is complex expression(s) I would suggest merging r.mapcalc calls. That can improve performance quite a bit (less data read and written) and reduces the need to manage temporary data.
See also: https://grass.osgeo.org/grass74/manuals/r.mapcalc.html#multiple-computations
If you don’t need the first_… To fifth_… files later, I would even say everything in 3rd_procedure.py until r.to.vect could be solved in a single mapcalc operation…
Thank you so much for your hints! I’m trying to clean up the code without creating a too complex expression…I hope to share the new version by this evening or tomorrow at the latest.
Kind regards and again thank for your GSoC work,
Stefan
Thanks again!!
Roberta
From: grass-dev <grass-dev-bounces@lists.osgeo.org> on behalf of Roberta Fagandini <robifagandini@gmail.com>
Sent: Sunday, May 20, 2018 4:33:57 PM
To: soc@lists.osgeo.org; GRASS developers list
Subject: [GRASS-dev] ​GSoC 2018 report week 01 - GRASS GIS module for Sentinel-2 cloud and shadow detection
Hi all!
I’m Roberta Fagandini and I’m working on my GSoC project, a GRASS GIS module for Sentinel-2 cloud and shadow detection.
This is my report for the first week of coding.
Since my progress has been a bit faster than expected I have already discussed with my mentors about further additions to the project. Therefore I have already updated my wiki page [0] changing the timeline. In this way, I will be able to release a more complete module.
1) What did I complete this week?
  • Checked the prototype version of the algorithm for cloud and shadow detection
  • Tested it
  • I better studied the documentation of the GRASS Python Scripting Library and started coding the GRASS python script following the workflow schema prepared during the bonding period [1]
  • Coded the ‘data preparation’ phase
  • Coded the clouds detection procedure
  • Added this first part of python script to my GitHub repository [2]
  • Discussed with my mentors about further additions
  • Discussed with the community about testing phase. I received some feedback and some developers stepped forward to help me in testing the algorithm
  • Shared progress with the community
Unfortunately, I wasn’t able to code on Thursday because of a PhD meeting with my supervisor.
2) What am I going to achieve for next week?
  • Finish the translation of the algorithm in a basic python script adding the shadows detection procedure and the steps for checking and cleaning the final outputs (see [1] for details)
  • Improve the python script so as to have a “light” working python script (manage temporary file, clean up the code, etc.)
  • Test it and fix bugs
  • Start implementing the GUI
3) Is there any blocking issue?
No at the moment.
Best wishes,
Roberta
[0] https://trac.osgeo.org/grass/wiki/GSoC/2018/CloudsAndShadowsDetection
[1] https://drive.google.com/file/d/1KYEKvNBurBFHw1xUTLjM0PW80Z-7br81/view?usp=sharing
[2] https://github.com/RobiFag/GRASS_clouds_and_shadows
Ciao Roberta,
Thanks, that was exactly what I had in mind!
When you find the time you could consider the following further improvements:
  • Scaling in the beginning: Currently input is scaled with a hard-coded factor, that is not necessarily generic. You could either:
  1. Drop scaling completely and document in the manual how input should be scaled. Esp. if the input to your algorithm is output from i.atcorr, as i.atcorr has a scaling option for output.
  2. Make scaling factor a parameter that users can provide (would be useful if atmospheric correction is performed with other tools than i.atcorr)
  • Band statistics: It seems you are computing “zonal statistics” with just one zone which in practice will be a sort of global maximum per band. In that case you do not need a map and can use a constant in r.mapcalc.
    If you need to use global maximum reflectance per band, you could use:
gscript.parse_command(‘r.info’, flags=’g’, …) if the maximum for the entire map is needed. This would be the fastest option.
If you need to use maximum within current computational region (or e.g. with a different mask applied) you could use:
gscript.parse_command(‘r.univar’, flags=’g’, …); then statistics are computed
From that you get “max” as a variable.
Just for inspiration…
Kind regards,
Stefan
Sent: onsdag 23. mai 2018 17.07
To: GRASS developers list grass-dev@lists.osgeo.org
Cc: Stefan Blumentrath Stefan.Blumentrath@nina.no; Roberto Marzocchi roberto.marzocchi@gmail.com; Moritz Lennert mlennert@club.worldonline.be; soc@lists.osgeo.org
Subject: Re: [GRASS-dev] ​GSoC 2018 report week 01 - GRASS GIS module for Sentinel-2 cloud and shadow detection
Hi all!
Thanks in advance!
Roberta
Ciao Stefan!
Ciao Roberta,
Stefan
Thanks again!!
Roberta
Hi all!
  • Tested it
No at the moment.
Best wishes,
Roberta
Ciao Stefan!
2018-05-25 11:19 GMT+02:00 Stefan Blumentrath <Stefan.Blumentrath@nina.no>:
Ciao Roberta,
I’m still cleaning the code managing temporary file and arranging it in order to add the GUI next week! I hope the next version will be even better (I’m going to upload it later in the afternoon).
Thank you for your suggestions, they are so useful for me!
I agree with you! The next month aim is to implement an automatic procedure to run i.atcorr within mine, retrieving automatically all necessary parameters for the control file. Therefore, I think making the scaling factor an user-defined parameter can be the best choice, in this way users can choose their own factor or to not use it in case the atmospheric correction is performed with i.atcorr or within the cloud and shadow detection procedure. At the moment I have changed the code defining the scaling factor as a variable, this should help in managing the GUI for this step.
You’re right! At the moment I manage the stats maps as temporary files but actually, it is not necessary to create them…I have already change the code.
Thank you for the hint! these will certainly help me…I’m a bit messy!
Kind regards,
Stefan
Kind regards,
Roberta
To: GRASS developers list <grass-dev@lists.osgeo.org>
Cc: Stefan Blumentrath <Stefan.Blumentrath@nina.no>; Roberto Marzocchi <roberto.marzocchi@gmail.com>; Moritz Lennert <mlennert@club.worldonline.be>; soc@lists.osgeo.org
Hi all!
Thanks in advance!
Roberta
Ciao Stefan!
Ciao Roberta,
Stefan
Thanks again!!
Roberta
Hi all!
  • Tested it
No at the moment.
Best wishes,
Roberta
