[GRASS-dev] GSoC 2021: Week 10: First steps towards a new GRASS GIS Single-Window GUI
Hello everyone,
I am sending my Week 10 report (August 9 - August 13). It can be also found at the project wiki: https://trac.osgeo.org/grass/wiki/GSoC/2021/SingleWindowLayout#Week10.
1) What did I complete this week?
First of all, I fixed the size of the automatic notebook which is used for the startup layout. The related PR [1] has still some minor shortcomings with cmd warnings messages but we decided to let it be for now since it would require more intervention in the construction of the map panel status bar widget which is anyway likely to be very simplified or replaced by the settings dialog in the future.
Secondly, I implemented the new changing tab event for the center AuiNotebook. You can have a look at PR [2] which is already merged. To provide the fully working GRASS Single-Window GUI prototype, I also opened the PR [3] which addresses several smaller things related to the AuiNotebook closing event. This PR is not merged yet but I plan to have it done by the end of GSoC. Merging this PR will close the Issue [4] with the new AuiNotebook events.
Thirdly, I moved the NewDisplay button to the upper Tools toolbar, see the PR [5] (merged).
Lastly, each layer tree is about to have one independent toolbar. I have coded it in the PR [6] which is not in the master branch yet.
2) What am I going to achieve for next week?
The priorities for the next week are mainly to finish PRs [3] and [6]. Unfortunately, we still have not merged the main refactoring PR [7] because it waits for the GRASS 8 release.
It probably gets into the GRASS dev version after GSoC.
Anyway, I would also like to prepare some startup settings that allow GRASS geeks to try out the GRASS Single-Window prototype. And of course, I am going to finish the final evaluation and sum up my work to the final GSoC report.
3) Is there any blocking issue?
No, It is not. Please, if you would like to know more info, have a look at my Twitter thread [8] where I presented some screenshots of the prepared GUI. :slight_smile:
[1] https://github.com/OSGeo/grass/pull/1775
[2] https://github.com/OSGeo/grass/pull/1780
[3] https://github.com/OSGeo/grass/pull/1789
[4] https://github.com/OSGeo/grass/issues/1750
[5] https://github.com/OSGeo/grass/pull/1783
[6] https://github.com/OSGeo/grass/pull/1785
[7] https://github.com/OSGeo/grass/pull/1675
[8] https://twitter.com/GRASSGIS/status/1423254298587275264
Best wishes,
Linda Kladivova
