Hello everyone,
I am sending my Week 6 report (July 12 - July 16). The more detailed version can be found at the project wiki: https://trac.osgeo.org/grass/wiki/GSoC/2021/SingleWindowLayout#Week6.
1) What did I complete this week?
This week was very important. In the first part, I worked on PR [1] which is already done in terms of the main Map Display panel but needs many other changes related to other widgets. On Wednesday’s video call we decided to work on the local merged branch because it will probably take some time to merge PR [1] (also with regard to the new G8 release). So, I set up the new PR [2] mining from both refactoring PRs [1], [3]. By the time we merge them, I can solve here many things related to the Single-Window GUI… I have already composed the new Map Display panel and started to repair existing events and methods and to implement new methods. There are several basic things I would like to address in this PR:
- repair GRASS GIS exit (generally speaking all closing stuff is broken now)
- adding maps to map display does not work when switching to a different location
- adding and removing 3D View does not work
- remove methods applied on wx.Frame
- implement new events or repair the existing ones
- when renaming the Display tab, the related Map notebook tab is renamed
I have also noticed a small issue concerning g.gui.iclass toolbars and I set up the issue for it (see [4]).
2) What am I going to achieve for next week?
I am gonna work on coding the above-mentioned basic functionalities for the Single-Window layout on my locally merged branch. Although, it is not possible for my mentors to test it, I will share changes to the PR [2] so we can at least discuss them.
3) Is there any blocking issue?
No, It is not.
[1] https://github.com/OSGeo/grass/pull/1675
[2] https://github.com/OSGeo/grass/pull/1732
[3] https://github.com/OSGeo/grass/pull/1689
[4] https://github.com/OSGeo/grass/issues/1731
Any suggestions are welcome.
Best wishes,
Linda Kladivova
