Hello All,
I’m applying to Google Summer of Code to work on the “Seamless integration of GRASS GIS and Jupyter Notebooks” project [1]. I’ve written a draft of my application [2] and I’d be grateful for any feedback from the GRASS-dev community.
I’m also including a brief summary of my ideas here. I hope to make a Python module or package called grass.jupyter that will make GRASS easier to use and more intuitive in Jupyter Notebooks (for an example of the current integration, see [3]). I’m proposing to work on three main tasks:
(1) updating the launch of GRASS GIS in Jupyter Notebooks by introducing a new startup function that will make GRASS initiation more succinct by setting default options (i.e. raise exceptions, show standard output and allow overwriting).
(2) creating a more intuitive way to display maps by creating a new class called grassRenderer
(3) introducing an interactive map display function using folium, a python mapping package that creates interactive maps.
I’d love any feedback on those ideas and on my attached proposal [2]. In particular, I’m interested in your thoughts about the interactive map display workflow. My current plan would be to render images with GRASS (d.rast and d.vect) then overlaying the resulting .png image in folium using the georeferencing information from the GRASS region. An alternative would be to export GeoTIFF/GeoJSONs then import these to folium. The user would then set the coloring and style options in folium. The advantages of the latter would be better display of vector data (since it is not rasterized) and more future options for interactivity (such as turning on and off layers). But, it could also make layer styling and coloring more difficult and add complexity to the module.
Thank you and Happy Friday,
Caitlin
[1]https://trac.osgeo.org/grass/wiki/GSoC/2021
[2] https://docs.google.com/document/d/1GC3Jc9sDRRPUJSFi3Okvep1N0VCiJkwxVcYZwQtKOag/edit?usp=sharing
