[GRASS-dev] GSoC idea: v.in.osm enhancement
hi,
just read in https://trac.osgeo.org/grass/wiki/GSoC/2017#v.in.osmenhancement
"Until now a script, called v.in.osm, exists, but it is able to import data
only from a PostgreSQL database after using ​osm2pgsql to convert OSM format
to PostgreSQL/PostGIS. This project has to implement the capabilities to
import directly the .osm or .pbf format."
just see the example
https://grass.osgeo.org/grass72/manuals/addons/v.in.osm.html
Import from OSM PBF file:
v.in.osm input=saarland-latest.osm.pbf table=lines type=point,line
output=roads \
         where="highway is not null"
so it seems v.in.osm is already able to read pbf-files.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GSoC-idea-v-in-osm-enhancement-tp5304492.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
On 23 January 2017 at 16:52, Helmut Kudrnovsky <hellik@web.de> wrote:
hi,
only from a PostgreSQL database after using osm2pgsql to convert OSM format
output=roads \
Probably the proposal was written before the addons :wink:
ciao
Luca
www.lucadelu.org
2017-01-24 16:30 GMT+01:00 Luca Delucchi <lucadeluge@gmail.com>:
so, should we remove this idea? Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On 25 January 2017 at 10:25, Martin Landa <landa.martin@gmail.com> wrote:
no, the new v.in.osm support PBF but more improving could be done. I
will modify the idea...
ciao
Luca
www.lucadelu.org
2017-01-25 10:31 GMT+01:00 Luca Delucchi <lucadeluge@gmail.com>:
thanks, Ma
Martin Landa
thanks, Ma
I read better the proposal, is still valid instead is possible to read
pbf/osm file only using osm2pgsql but the proposal would like to have
different backend options
ciao
Luca
www.lucadelu.org
Luca Delucchi wrote
On 25 January 2017 at 10:36, Martin Landa &lt;
landa.martin@
&gt; wrote:
2017-01-25 10:31 GMT+01:00 Luca Delucchi &lt;
lucadeluge@
&gt;:
thanks, Ma
sorry, don't understand right above.
from the proposal:
to PostgreSQL/PostGIS.This project has to implement the capabilities to
.pbf format can already be read.
see the manual: https://grass.osgeo.org/grass72/manuals/addons/v.in.osm.html
EXAMPLES
Import from PostgreSQL DB:
v.in.osm input="PG:host=localhost dbname=gis user=ostepok"
table=planet_osm_line \
         type=point,line output=roads where="highway is not null"
output=roads \
so maybe the gsoc proposal has to be adapted to extended backend support.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GSoC-idea-v-in-osm-enhancement-tp5304492p5305136.html
