[GRASS-dev] GSoC ideas - vector legend, medial axis
Hello,
I’m thinking about participating in GSoC this year, if I find some interesting topic. I went through GRASS GSoC ideas. The two most interesting for me are Vector legend and Extracting the medial axis of polygon. I would appreciate if anyone can give me more information to these topics.
The first one is maybe described enough and I just need to study that more to understand it better, but still anything more regarding that would be appreciated.
The medial axis is not really clear to me. I know what is medial axis, but I would like to know more about desired results. How it should be integrated to GRASS (some new module?). Is it necessary to write it in C (why not python)? Should the result algorithm extract the exact medial axis or the approximation? …
And one more question. Is any of these topics suitable for me if I am not experienced in GRASS at all?
Thank you
Tereza Fiedlerová
Hi Tereza!
On Thu, Feb 20, 2014 at 9:08 AM, Tereza Fiedlerová <tfiedlerova@gmail.com> wrote:
Please consider the idea on metadata, that requires a limited knowledge of GRASS I would say
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
Hello,
I'm thinking about participating in GSoC this year, if I find some
appreciated.
approximation? ...
A good approximation would be fine. It would be necessary to write in
C for efficiency reasons and because C library functions need to be
heavily used. Additionally, search structures like balanced binary
search trees and min heaps are needed which are already implemented in
GRASS as C code. I have already written 2 different C modules trying
to extract the medial axis, both are incredibly complex and none of
them works properly. I am familiar with GRASS, C, and Python and like
to use the easiest approach. In this case I am pretty sure that the
easiest and most appropriate approach is using C, not Python.
Therefore I would recommend a good knowledge of C and some knowledge
of the GRASS C API for this project.
Markus M
Thank you
Tereza Fiedlerová
grass-dev mailing list
grass-dev@lists.osgeo.org
On Thu, Feb 20, 2014 at 4:06 PM, Markus Metz
> Hello,
interesting
would
more
> appreciated.
but I
integrated
> approximation? ...
Markus M
Just in case it would be useful (at least for Tereza, it's mostly in Czech):
http://web.natur.cuni.cz/~bayertom/Adk/adk7.pdf
this is a presentation on straight skeleton algorithm (if medial axis is
the same or at least related?).
Anna
> Thank you
> Tereza Fiedlerová
On Thu, Feb 20, 2014 at 10:47 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
On Thu, Feb 20, 2014 at 4:06 PM, Markus Metz <markus.metz.giswork@gmail.com>
> Hello,
> interesting
> would
> more
> appreciated.
> but I
> integrated
> the
> approximation? ...
Markus M
this is a presentation on straight skeleton algorithm (if medial axis is the
A straight skeleton is not the same like a medial axis: only the
medial axis is equidistant to the polygon boundaries.
Markus M
Anna
> not
> Thank you
> Tereza Fiedlerová
finally I considered the metadata topic is probably the most appropriate for me. My aim now is to find out as much as I can about it to have better idea what is going on. If you have any additional information or resources I could study, please let me know. Thanks
Tereza
On 20 February 2014 09:33, Margherita Di Leo <dileomargherita@gmail.com> wrote:
Hi Tereza!
Best regards,
Via Fermi, 2749
2014-02-24 20:18 GMT+01:00 Tereza Fiedlerová <tfiedlerova@gmail.com>:
perfect, in this regard I would like to open discussion whether to
speak just about metadata (ISO, Inspire) or also about supporting
Inspire services (view and download)...
Martin
A good metadata tool that generates ISO compliant xml would be very useful and a substantial accomplishment by itself.
Doug
On Mon, Feb 24, 2014 at 2:22 PM, Martin Landa <landa.martin@gmail.com> wrote:
Inspire services (view and download)…
Martin
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb@fws.gov
The opinions I express are my own and are not representative of the official policy of the U.S.Fish and Wildlife Service or Dept. of the Interior. Life is too short for undocumented, proprietary data formats.
(thanks for the great ideas pages everyone: osgeo gsoc 2014 is accepted and happening!)
integrating an existing open source metadata library instead of starting from scratch would be faster and easier to maintain in
the long run. :slight_smile:
e.g. try to cooperate with the GeoNetwork and pycsw teams. is qgis doing anything wrt metadata that we could share development with?
Hamish
see also deegree, qgis MetaSearch plugin, and the OSWLib library.
Hamish
Hi All,
On Mon, Feb 24, 2014 at 8:22 PM, Martin Landa <landa.martin@gmail.com> wrote:
Tereza, I’m glad to hear that. As several hints have already come, I’d suggest to set a page in the trac where we can store all these inputs that otherwise would be difficult to find again.
Martin, this makes sense, but I’d stick with a target that is reachable within the GSoC. Of course the occasion is suitable to gather all the ideas which can be developed in the future.
MaDi
Best regards,
Via Fermi, 2749
From what I understand, the ISO 19115-1 metadata standard should be finalized shortly. Getting an official copy of the standard for this work ( if they finalize in time) would be useful.
Doug
On Tue, Feb 25, 2014 at 4:36 AM, Margherita Di Leo <dileomargherita@gmail.com> wrote:
Hi All,
Doug Newcomb
USFWS
Raleigh, NC
MaDi
Best regards,
Via Fermi, 2749
I had a chat with Antony Scott a while back about a metadata component to this plugin:
https://github.com/mapaction/RAMP-QGIS
I have not kept up with the progress of the plugin.
Doug
On Mon, Feb 24, 2014 at 5:53 PM, Hamish <hamish_b@yahoo.com> wrote:
Hamish
Doug Newcomb
USFWS
Raleigh, NC
Metadata code reference:
https://geo-ide.noaa.gov/wiki/index.php?title=ISO_19115_and_19115-2_CodeList_Dictionaries
Doug
On Tue, Feb 25, 2014 at 3:36 PM, Antony Scott <antony.scott@gmail.com> wrote:
Doug/all,
First, my apologies for not responding to your earlier nudge. However there’s not a great deal to report on the plugin - MapAction remains keen to take it forward, but doesn’t have the development resources at the moment to be able to do much about it. We’d be happy to expand on the documentation though, and the osgeo gsoc could be an opportunity to get things moving if people were interested. Certainly our experiences in the Philippines last year underlined our need for better metadata creation and management tools, so it’s high on our list of action points for follow up.
Look forward to seeing how things develop, and we’ll see if there’s anything we can contribute.
regards
Ant Scott
Doug Newcomb
USFWS
Raleigh, NC
Doug
Hamish
Doug Newcomb
USFWS
Raleigh, NC
Another QGIS plugin effort.
http://gis-lab.info/qa/metatools-eng.html#Working_with_FGDC
Doug
On Thu, Feb 27, 2014 at 12:56 PM, Newcomb, Doug <doug_newcomb@fws.gov> wrote:
Doug
Doug Newcomb
USFWS
Raleigh, NC
Doug/all,
regards
Ant Scott
Doug Newcomb
USFWS
Raleigh, NC
Doug
Hamish
Doug Newcomb
USFWS
Raleigh, NC
