Dear dev team,
I would like to propose an idea for the 2017 GSoC (it is already on the GSoC 2017 GRASS wiki page).
It will be focused on ‘meaningful’ cutline generation. I recently read a paper describing a method for cutline generation (see below [1] for the article, [2] for more references).
The procedure is composed of the following main steps:
- Apply a High-pass filter - the “Prewitt South” filter (https://en.wikipedia.org/wiki/Prewitt_operator) to produce an edge image;
- Apply a low-pass filter (mean for example) on the previous result;
- Find the starting and finishing points (just based on pixel values in the first/last column/row);
- Create an adjacency matrix on the result of 2) and use weights to give higher costs for specific directions (and force the cutline in to be quite linear between starting and finishing points);
- Use the Dijkstra’s algorithm (https://en.wikipedia.org/wiki/Dijkstra’s_algorithm) to find the optimal cutline with a lowest cost between the starting and finishing point
Finding meaningful cutline in the image could be very interesting for tiling images in order to process segmentation in parallel. Instead of using arbitrary linear tiling, the segmented tiles could then be merged without post-processing of segments touching the tile’s border.
If this algorithm would be implemented during the GSoC, it could be further adapted for huge enhancement of i.image.mosaic to enable mosaicking of overlapping scenes using cutline and become a real alternative to proprietary software (http://gis.stackexchange.com/questions/127310/how-to-create-a-mosaic-in-qgis-with-cutline-and-feathering-for-landsat-8-imagery).
As the proposed solution [1] for cutline is working on a single image, It should be adapted to take into account pixel values of two images so.
I can give a support for the content of the project, but I don’t have the necessary programming skills for supervision of GSoC student. So, I would like to know if someone would be interested by being the mentor for this project !
Concerning the language requirements for this project I guess it will be C ?
[1] Soares, Anderson Reis, Thales Sehn Körting, et Leila Maria Garcia Fonseca. 2016. « Improvements of the divide and segment method for parallel image segmentation ». Brazilian Journal of Cartography 68 (6). https://www.researchgate.net/publication/286929006_Improvements_of_the_divide_and_segment_method_for_parallel_image_segmentation
[2] Körting, Thales Sehn, Emiliano Ferreira Castejon, et Leila Maria Garcia Fonseca. 2013. « The Divide and Segment Method for Parallel Image Segmentation ». In Advanced Concepts for Intelligent Vision Systems, 504 15. Springer, Cham. doi:10.1007/978-3-319-02895-8_45. https://www.researchgate.net/publication/265794792_The_Divide_and_Segment_Method_for_Parallel_Image_Segmentation
Best,
(attachments)
M. GRIPPA Taïs
Geographer - Phd student IGEAT - ANAGEO
ULB CP 130/03 Av. F.D. Roosevelt, 50 - 1050 Bruxelles
Tél: 02/650.68.06
Mail: Tais.Grippa@ulb.ac.be
Web: http://maupp.ulb.ac.be/
