[GRASS-dev] GUI platforms
First, I am not trying to be combative at all. I wish we could sit
down at a coffee shop and discuss over a latte...
I agree that the current incarnation of GRASS and probably for the
near future there will be no major changes to GRASS. What I am
thinking about is GRASS 7 (or maybe GRASS 8).
The problem is not the particular shell used (though there are
advantages to establishing a standard), it is the missing toolbox on
Windows. Windows out-of-the-box doesn't provide the tools to do
anything useful. Everything needs to be provided. There are several
options:
1. You can supply a Unix emulation layer and bash as Cygwin does
(there are others) and all scripts run cross-platform across the three
architectures. This is what is being done today.
2. You supply a tool set and allow Windows to use a native shell (cmd
or whatever). I think in this case the obvious easy path is to supply
the tools already available on Unix systems, but recreating a new tool
set isn't inconceivable. Care needs to be taken to make this all work
cross-platform without crippling one system or the other. I can't
imagine that true cross-platform scripting can be achieved this way
without essentially duplicating what Cygwin already provides.
3. You code to the lowest common denominator making no assumptions
about a Unix toolbox or a scripting environment. Here is where you
will probably need to supply grass with its own "shell". Maybe a
Python interpreter with an object model for communication with GRASS
(like ArcGIS has done).
IMHO, option 3 ends GRASS as a real Unix program.
Part of the issue is that 99% of tools designed for native use on
Windows (and GUI Mac) are not programmed to use text streams. The only
way to communicate with them is through remote procedure calls. That
is why Windows provides the Windows Scripting Host (WSH). Python and
Perl use COM, etc. GRASS's shell will need to support this world view.
If you've done much scripting in Windows using native tools, you'll
find it is a very different monster than on Unix. Your code becomes
boiler plate procedure calls to the scripting host and you work with
the back-end API of things like MS Office applications. One line of
bash with a few pipes turns into dozens of lines of object-oriented
goop, even in Python.
Certainly, if we are going down that route I would rather see it in
Python than almost any other scripting language. But I think this
approach has long-term implications for the GRASS architecture that go
well beyond the GUI issues we are dealing with today.
It's something to think about.
On 5/23/06, twiens <twiens@interbaun.com> wrote:
----- Original Message Follows -----
From: "David Finlayson" <david.p.finlayson@gmail.com>
To: "Michael Barton" <michael.barton@asu.edu>
Cc: Trevor Wiens <twiens@interbaun.com>, Glynn Clements
<glynn@gclements.plus.com>, grass developers list
<grass-dev@grass.itc.it>
Subject: Re: [GRASS-dev] GUI platforms
Date: Tue, 23 May 2006 10:13:23 -0700
> >> Is the goal to eliminate the GRASS dependency on a Unix
> environment?
> > Yes. GRASS should also work on Windows (with neither
> > Cygwin nor an X server) and MacOSX (without an X server)
> as well as it does on Unix.
> As I said, that IS throwing the baby out with the
> bathwater.
David,
Shell environments are available on other platforms. FYI, M$
is currently planning on doing a serious upgrade of the
shell environment for their upcoming Vista release. If
however that actually happens.... who knows. Also, FYI, I
only use Linux and like it, but that doesn't mean I don't
want to provide GRASS to others if it can be done without
loss of functionality that I need and use.
The point is creating independence from X11 and providing a
shell does not in any way compromise the use of sed, awk,
etc. What we can't count on is an xterm or equivalent being
open, thus we need to provide an integrated shell. This
simply could take the form of an xterm or something more
involved like Cedric's recent work with gis.m.
I had simply asked a question about what was being planned.
Michael clearly stated that Bash is NOT scheduled for
removal. If you read Radim's responses you would find that
all these tools can be setup and called from Windows.
All the shell scripts written for GRASS will still work in
the future. Hopefully we will be able to provide a more
sophisticated scripting environment in the future for those
who choose to use it, but it is simply too much work to
rewrite all the shell based stuff.
What Windows won't have is the low cost of spawning
processes, but that is a Unix (os not shell) design issue
over Windows.
No one wants to abandon the simplicity of the fundamental
principle of one program for one task. To do that would be
starting over from scratch and no one wants to do this.
Please read the queries posted by Russ Nelson about wanting
to rewrite GRASS from scratch. NO ONE WANTS THAT. As Glynn
clearly stated, nothing is being thrown out. No
functionality will be lost and your replies do not in any
way demonstrate how the move to independence from X11 will
cause any loss in functionality.
> snip....
> done. Something more sophisticated will reduce the pool of
> programmers accordingly.
Absolutely false. Providing a modern scripting language will
increase the number of programmers not reduce it. Since
shell and all that comes with it will still be available you
will still be able to get things done.
> Eliminate Unix and in one fell swoop every script in GRASS
> is unusable. All 50+ of the official scripts will need to
> be rewritten in Python or whatever the script language de
> jour is. Some things that we take for granted today (like
> grep, sed, awk, head, tail, cut...), stuff I use every day
> , is going too. Every one of them will need an OS-specific
> replacement or complete recode in a portable language.
This is not planned and has never been suggested.
> snip....
> What you guys are proposing with the GUI change is really
> much more than that. It is a fundamental re-architecture
> of the GRASS program. A few of us have been alarmed by it.
> Maybe a lot more people are relieved. But at any rate it
> seems like that decision should be more transparent to the
> community of GRASS users.
Since NO drastic change is happening what would users be
asked?
"Would you like the GUI to be nicer?" __YES / __ NO
T
Trevor Wiens
David Finlayson
options:
bash, along with most of the common text-processing tools are
available in versions which don't require Cygwin. They've been
available in the MKS toolkit for decades, and there's also the
GNU-Win32 project.
That kind of program really doesn't need accurate Unix compatibility;
you just need to be able to read and write files. The level of
compatibility which Cygwin provides just creates complications (and
also incurs a massive performance penalty).
This is up to the user. If I was developing an in-house tool based
upon GRASS, I wouldn't use bash for any non-trivial scripts. If you're
planning on distributing the software, you need to consider the target
audience. If your target audience lives and breathes Windows, bash
would be the wrong choice; you would be better of with cmd.exe batch
files, in spite of cmd.exe being the only language in existence which
is objectively worse than bash as a programming language.
There's still the issue of which language to use for any scripts
included as part of GRASS. While we currently use Bourne shell (well,
there are probably a few bash-isms in some of the scripts, but we
usually fix those if someone points them out), you could make a
reasonable argument for using Perl instead. On Unix, it's almost as
commonplace as /bin/sh nowadays; on Windows, it's probably more
common. Regardless of platform, it has to be a better language than
bash (FWIW, I don't like Perl; but then I'm not particularly fond of
using bash for anything longer than 10 lines either).
That isn't going to happen. If GRASS ditched bash in favour of Perl or
Python for its standard scripting language, the scripting interface
would still be through spawning commands, redirecting/piping
stdin/stdout, reading/writing files etc.
Switching to COM/CORBA/OLE/RPC/etc wouldn't be an issue of GRASS no
longer being a Unix program, but an issue of it no longer being GRASS.
It would require a complete top-to-bottom rewrite, and that isn't
going to happen.
We aren't going down that route.
