[GRASS-dev] GV_VOLUME: does it exist?
could anybody enlighten me about the status of the GRASS 3D
geometry type "GV_VOLUME"? I assume this is meant to be
the equivalent of the 2D "GV_AREA", i.e. GV_KERNEL + GV_FACE(S)?
Is there some actual Vect library level support for processing
such geometries or does GV_VOLUME just exist as a symbol for
completeness' sake? So far I could not spot it in the "type="
option of any GRASS module.
Happy coding,
Ben
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
geometry type "GV_VOLUME"? I assume this is meant to be the equivalent
AFAIU it is only really used by NVIZ so far for displaying 3D vector
volumes*, but I think it is important to keep it in a state ready to be
implemented :slight_smile:
[* e.g. v.in.dxf (not -f) -> nviz
http://bambi.otago.ac.nz/hamish/grass/screenshots/nyc3d_nviz3_midtown.png
not much as far as I've found, but hopefully that will change one day.
better defining it's purpose would definitely help.
one question I've always had: do kernels exist as centroids within a
closed volume (center of empty soccer ball), or one of the surface of
every 3D face? (ie on on each hexagonal/pentagonal patch of the soccer
ball)
Hamish
