On Thu, 6 Oct 2022 at 13:46, Daniel Torres <nobeeakon@gmail.com> wrote:
Hi guys,
are we doing anything for hacktober? I see some 2021 issues in the grass repo tagged as hacktober,
…and the grass and grass-addons repos are tagged and I’m ready to do some reviews. I just didn’t have any capacity to do the promotion myself and I don’t know how many people here follow Hacktoberfest (you can, after all, do the proper Octoberfest), but yes, we are active although there was no announcement.
but wondering if it would make sense to make some announcement on the site (maybe a dialog when landing in the home, or somewhere in the home )
Yes.
and if there are non coding (docs and so on) or first issues we could add for this (for the grass website or the grass repo).
I did not check the new rules in relation to the website, but non-coding PRs in grass and grass-addons will count for sure and with the label, we are set.
Also, asking again about the docs improvements. Vaclav mentioned some time ago he would like to see some work on that side, and on JavaScript checks in Super-Liner .
The checks are more straightforward, so a better fit for Hacktoberfest. Also, having HTML/CSS/JS checks in place is a good basis for changing the documentation because we can merge with greater confidence.
As said before, I’m mostly on frontend stuff and happy to help with that (although I’d need some guidance as I’m not familiar with the code and so on…) or if you think I’d be helpful in other things, let me know.
If you see something which hurts your eyes or feels really clunky, that might be a place to start (that might be code, CLI, or documentation on mobile). Someone will likely be able to point you to the right code. …or suggest trying something else first
Best,
Vaclav
