[GRASS-dev] heads up: changes in the UI of i.cutlines
If any of you use i.cutlines, watch out: in order to simplify and clarify its interface, I changed some parameter names and reduced the output options to just the vector tiles.
So there has been a change in interface to the module.
I also added the option to provide the module with existing cutline vector maps for guidance.
https://trac.osgeo.org/grass/changeset/73551/
Moritz
