[GRASS-dev] Heisenbug in v.out.ascii with column parameter: segfault
I had the same problem before. It is typical for bad
string management, where uninitialized memory is written
to or read from to just such an extent, that it works
most of the time. When you run valgrind or gdb, the memory
mapping of v.in.ascii will be slightly different and this
might just allow it to get away with its dirty mem handling.
In my case, running valgrind with options --leck-check=full
succeeded to give me some additional hints about the culprit.
Also, make sure to use the latest valgrind version.
If that gets you nowhere, could you maybe attach your
data (or part) of it to a Trac ticket, so we can make this
bug "official" and others can get a chance to take a poke
at it?
Ben
Soeren Gebbert wrote:
Hmmm, the bad thing is that the segfault disappear when using valgrind.
The uninitialised value report must not point to the root of the segfault.
To enable detailed information, grass must be compiled with debug
information ... .
I don't know what to do.
Best regrads
Soeren
2009/9/9 Markus Neteler <neteler@osgeo.org <mailto:neteler@osgeo.org>>
    Here we are:
    GRASS 6.4.0svn (patUTM32):~ > valgrind --tool=memcheck v.out.ascii
    phd_area_main_cities column=name
    ==26104== Memcheck, a memory error detector.
    ==26104== Copyright (C) 2002-2007, and GNU GPL'd, by Julian Seward
    et al.
    ==26104== Using LibVEX rev 1854, a library for dynamic binary
    translation.
    ==26104== Copyright (C) 2004-2007, and GNU GPL'd, by OpenWorks LLP.
    ==26104== Using valgrind-3.3.1, a dynamic binary instrumentation
    framework.
    ==26104== Copyright (C) 2000-2007, and GNU GPL'd, by Julian Seward
    et al.
    ==26104== For more details, rerun with: -v
    ==26104==
    ==26104== Conditional jump or move depends on uninitialised value(s)
    ==26104== at 0x4E4F408: db_enlarge_string (in
    /home/neteler/binaries/grass-6.4.0svn/lib/libgrass_dbmibase.6.4.0svn.so
    <http://libgrass_dbmibase.6.4.0svn.so>)
    ==26104== by 0x4E4F50C: set_string (in
    ==26104== by 0x4E4FD39: db_copy_value (in
    ==26104== by 0x54DC58D: db_select_value (in
    /home/neteler/binaries/grass-6.4.0svn/lib/libgrass_dbmiclient.6.4.0svn.so
    <http://libgrass_dbmiclient.6.4.0svn.so>)
    ==26104== by 0x40210E: bin_to_asc (in
    /home/neteler/binaries/grass-6.4.0svn/bin/v.out.ascii)
    ==26104== by 0x402A79: main (in
    ==26104==
    ==26104== at 0x4E4F417: db_enlarge_string (in
    664070.15136424|5103723.69345589|1|Trento
    680631.89931785|5152080.37972013|2|Bolzano - Bozen
    748566.88848245|5114436.80436153|3|Belluno
    753217.48877466|5062320.47156408|4|Treviso
    783478.0559796|5095956.26859946|5|Pordenone
    ==26104==
    ==26104== ERROR SUMMARY: 2 errors from 2 contexts (suppressed: 5 from 1)
    ==26104== malloc/free: in use at exit: 20,632 bytes in 186 blocks.
    ==26104== malloc/free: 495 allocs, 309 frees, 46,512 bytes allocated.
    ==26104== For counts of detected errors, rerun with: -v
    ==26104== searching for pointers to 186 not-freed blocks.
    ==26104== checked 779,376 bytes.
    ==26104==
    ==26104== LEAK SUMMARY:
    ==26104== definitely lost: 13,863 bytes in 103 blocks.
    ==26104== possibly lost: 0 bytes in 0 blocks.
    ==26104== still reachable: 6,769 bytes in 83 blocks.
    ==26104== suppressed: 0 bytes in 0 blocks.
    ==26104== Rerun with --leak-check=full to see details of leaked memory.
    Doesn't tell me too much... :frowning: I guess an extra trick is needed to
    include
    DBMI checking.
    On Wed, Sep 9, 2009 at 12:14 PM, Soeren
    Gebbert<soerengebbert@googlemail.com
    <mailto:soerengebbert@googlemail.com>> wrote:
     > Hello,
     > try valgrind:
     > valgrind --tool=memcheck v.out.ascii phd_area_main_cities column=name
     > Sören
     > 2009/9/9 Markus Neteler <neteler@osgeo.org
     >> Hi,
     >> I get a Heisenbug [1] when exporting points from v.out.ascii with
     >> attributes
     >> (Scientific Linux, 64bit):
     >> GRASS 6.4.0svn (patUTM32):~ > v.out.ascii phd_area_main_cities
    column=name
     >> Segmentation fault
     >> GRASS 6.4.0svn (patUTM32):~ > gdb v.out.ascii
     >> GNU gdb Red Hat Linux (6.5-37.el5_2.2rh)
     >> This GDB was configured as "x86_64-redhat-linux-gnu"...(no debugging
     >> symbols found)
     >> Using host libthread_db library "/lib64/libthread_db.so.1".
     >> (gdb) r phd_area_main_cities column=name
     >> Starting program:
     >> /home/neteler/binaries/grass-6.4.0svn/bin/v.out.ascii
     >> phd_area_main_cities column=name
     >> (no debugging symbols found)
     >> [Thread debugging using libthread_db enabled]
     >> [New Thread 47548720613104 (LWP 7517)]
     >> [Detaching after fork from child process 7520. (Try `set
    detach-on-fork
     >> off'.)]
     >> 664070.15136424|5103723.69345589|1|Trento
     >> 680631.89931785|5152080.37972013|2|Bolzano - Bozen
     >> 748566.88848245|5114436.80436153|3|Belluno
     >> 753217.48877466|5062320.47156408|4|Treviso
     >> 783478.0559796|5095956.26859946|5|Pordenone
     >> Program exited normally.
    column=name
     >> Yes, I didn't compile with -g because it is my production
    machine but
     >> since it works in GDB...
     >> Any idea how to debug this problem?
     >> thanks
     >> Markus
     >> [1] http://en.wikipedia.org/wiki/Unusual_software_bug#Heisenbug
     >> _______________________________________________
     >> grass-dev mailing list
     >> grass-dev@lists.osgeo.org <mailto:grass-dev@lists.osgeo.org>
     >> http://lists.osgeo.org/mailman/listinfo/grass-dev
Benjamin Ducke
Senior Applications Support and Development Officer
Oxford Archaeological Unit Limited
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel: +44 (0)1865 263 800 (switchboard)
Tel: +44 (0)1865 980 758 (direct)
Fax :+44 (0)1865 793 496
benjamin.ducke@oxfordarch.co.uk
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
