[GRASS-dev] Help -> "About GRASS" broken
in GRASS 6, I currently get in
  File "/home/neteler/grass64/dist.x86_64-unknown-linux-
gnu/etc/wxpython/lmgr/frame.py", line 741, in OnAboutGRASS
win = AboutWindow(self)
gnu/etc/wxpython/gui_core/ghelp.py", line 483, in __init__
lang = '.'.join(locale.getdefaultlocale())
TypeError
sequence item 0: expected string, NoneType found
Hello,
I changed code a bit to not fail so hard in r53238 (6.4) and r53239
(7). Added one extra string 'unknown'
Still sometimes it will report wrong data, as Python's
getdefaultlocale is broken (by design?). On my system it sometimes
returns ('lv_LV', 'ISO8859-13') (as somewhere ISO encoding is set to
be default for lv_LV), still my system doesn't support provided ISO
encoding and attempt to use it in i.e. setlocale would cause only a
failure.
Maris.
2012/9/20 Markus Neteler <neteler@osgeo.org>:
TypeError
grass-dev mailing list
grass-dev@lists.osgeo.org
2012/9/20 Maris Nartiss <maris.gis@gmail.com>:
is there any reason why you skipped 6.5? It's strange to fix it in
release branch and not in dev branch... It source of problems we have
with inconsistency between relbr64 and devbr6. Too many branches...
(my opinion is still the same, to kill devb6).
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Hamish,
do you still need devbr6 (6.5)?
I thought that there was a broad consensus that devb6 (65) is not needed and can be retired
so that we have only 6.4.3 relbr64 and trunk 7.
Helena
On Sep 20, 2012, at 4:12 AM, Martin Landa wrote:
Martin
Yes, there is. Lack of disk space for 6.5 checkout and lack of time to make one.
Maris.
Martin
2012/9/21 Maris Nartiss <maris.gis@gmail.com>:
hm, done in r53260 to avoid that this fix will be lost in the future.
Martin
Helena wrote:
Hamish,
Yes, I do. To me it is very important and serves an invaluable role in
the maintenance of the old stable branch. (which I volunteer to maintain
in the long (long) term, even if lately I've been pulled away by other
responsibilities and a bit slack about keeping up with it)
thanks,
Hamish
On Mon, Oct 1, 2012 at 12:14 PM, Hamish <hamish_b@yahoo.com> wrote:
Helena wrote:
Hamish,
This is not clear to me.
.. this is exactly the problem - we don't have the resources to keep
6.5.svn in sync. As of today, there are major (!) differences due to
incomplete back- or forward porting. I did the cleanup job for a few
years, but I am getting tired of maintaining 6.5 for nothing.
2012/10/1 Hamish <hamish_b@yahoo.com>:
you are probably only one who wants to keep devbr6 alive (please
correct me if needed). To maintain - it means that you will backport
all commits from relbr64 to devbr6? Well, I am not serious, it will
not work. Probably we should vote about devbr6, you can always keep it
as your private branch somewhere...
Martin
