[GRASS-dev] Help needed Accessing Grass Modules through python
Dear All,
I am working on accessing grass functionalities through python, but I don’t know which way I should take to achieve this goal.
I have SWIG WIN, GRASS 6.3, Python 2.5, Quantum GIS 0.11
I want to call suppose “mapcalc” of grass from inside python.
Whether this is possible, If yes then how. Whether it can be achieved through g.parser, SWIG or through any other way.
Thank you in advance.
Bishwarup
2009/9/14 Bishwarup Banerjee <bishwarup.banerjee@gmail.com>:
I am working on accessing grass functionalities through python, but I don't
I want to call suppose "mapcalc" of grass from inside python.
I would suggest to use Python scripting library from GRASS >= 6.4 [1].
See raster.mapcalc().
Martin
[1] http://download.osgeo.org/grass/grass6_progman/pythonlib.html
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
The existing grass.mapcalc() function won't work in 6.4. That function
shouldn't have been backported from 7.0, as it requires the 7.0
version of r.mapcalc (which uses G_parser()).
It needs something like:
- if run_command('r.mapcalc', expression = e) != 0:
+ if write_command('r.mapcalc', stdin = e) != 0:
Either that, or use call(['r.mapcalc', expression]).
2009/9/14 Glynn Clements <glynn@gclements.plus.com>:
right, hopefully fixed in r39203.
Martin
Hi Martin and Glynn,
Thank you very much for your response. But as I am newbie to this block, I am not able to make out anything from your reply.
I suppose I am not able to clearly write the exact problem.
I have GRASS 6.3, Python 2.5 and working on Windows platform.
I need to access grass funtionalities from within my python program.
Now the question is How to do this?
On constant searching internet I found some material using g.parser, SWIG or python libs. But I am not sure how to proceed with this.
Or how to configure these, so that I can use them.
It will be very helpful to me if you can step by step tell me how to go ahead.
Thank you once again.
With Regards,
Bishwarup
On Mon, Sep 14, 2009 at 8:38 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
The existing grass.mapcalc() function won’t work in 6.4. That function
shouldn’t have been backported from 7.0, as it requires the 7.0
  • if run_command(‘r.mapcalc’, expression = e) != 0:
  • if write_command(‘r.mapcalc’, stdin = e) != 0:
Either that, or use call([‘r.mapcalc’, expression]).
On Tue, Sep 15, 2009 at 7:09 AM, Bishwarup Banerjee
As mentioned by Martin, GRASS 6.3 isn't really suitable. The
entire Python interface was redone in GRASS 6.4 and later, see
The page collects a series of examples, too.
Hi Markus,
Thank you very much for your valuable information. I have downloaded Grass 6.4 and also gone through the pythonlibs documentation. But how to configure the files now? So that I can access them from the python programs.
With Warm Regards,
Bishwarup
As mentioned by Martin, GRASS 6.3 isn’t really suitable. The
