melolp
1
I need some help since I'm new using GRASS functions through python.
I'm trying to use the function r.profile.
My code:
from grass.script import raster as grass
os.chdir('F:\GEOSTORM\Python scripts')
grass.run_command("r.profile",-g,input= teste1,output = teste, [12244.256
-295112.597,12128.012 -295293.77])
However I'm having the following error mesage:
"non-keyword arg after keyword arg grass.run_command"
Does someone can help me to write the correct code to call the r.profile
function from GRASS.
Best regards,
Pedro
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Help-run-r-profile-through-python-tp5707457p5707457.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
On Fri, Nov 5, 2010 at 1:35 AM, melolp <melolp@gmail.com> wrote:
My code:
I think that you need something like this (untested):
grass.run_command("r.profile", flags = "g" , input = teste1, output = teste,
profile = "12244.256,-295112.597,12128.012,-295293.77")
melolp wrote:
grass.run_command("r.profile",-g,input= teste1,output = teste, [12244.256 -295112.597,12128.012 -295293.77])
All arguments except the first are keyword arguments, i.e. "arg = val".
grass.run_command(
"r.profile",
Okay
-g,
This should be: flags = 'g'. "-g" would be the negative of a Python
variable namd "g".
input= teste1,
output = teste,
Okay
This should be:
profile = [12244.256,-295112.597,12128.012,-295293.77]
or:
profile = [(12244.256,-295112.597),(12128.012,-295293.77)]
i.e. you need to provide the keyword, and the argument must be a valid
Python expression. run_command() etc accept lists and tuples.
