[GRASS-dev] Helpp needed to call Grass from inside Python Plugin
Hi All,
I want to call the grass functionalities from inside my python plugins, in QGIS
For example: the Grass’s raster to polygon script, with out going inside the grass plugin.
Can I set the Grass Mapset, and location from inside my python plugin?
Is this possible?
my configurations are:
QGIS 0.11, GRASS 6.3, python 2.5, Windows
Thank you in advance
On Mon, Mar 22, 2010 at 1:28 PM, Bishwarup Banerjee
<bishwarup.banerjee@gmail.com> wrote:
Hi All,
QGIS
For example: the Grass's raster to polygon script, with out going inside the
grass plugin.
Is this possible?
I think yes. See also
http://grass.osgeo.org/wiki/GRASS_and_Python
(@all: please extend the Wiki page!)
Note that there are substantial improvements in GRASS 6.4+ for Python.
Hello Markus,
I have tried to iimplement the example in my way. The code is as follows
import os
import sys
import core as grass
def main():
input_map = options[‘H:/Shared_data/test1.tif’]
output_map = options[‘Test_24’]
ret = grass.run_command(“r.in.gdal”, input = input_map, output = output_map)
sys.exit(ret)
if name == “main”:
options, flags = grass.parser()
main()
But I get the following error, I cant make out where I am going wrong. I have set all the Env variables as suggested in the wiki page. Please help me to implement it.
F:\GRASS-6-SVN\etc\python\grass\script>python test.py
File “test.py”, line 18, in
File “F:\GRASS-6-SVN\etc\python\grass\script\core.py”, line 359, in parser
os.execvp(“g.parser.exe”, [name] + argv)
File “F:\Quantum GIS\python\os.py”, line 353, in execvp
_execvpe(file, args)
File “F:\Quantum GIS\python\os.py”, line 389, in _execvpe
func(fullname, *argrest)
OSError: [Errno 22] Invalid argument
With Regards
Bishwarup
Hi All,
QGIS
grass plugin.
Is this possible?
This should be:
  import grass.script as grass
or:
  import grass.script.core as grass
def main():
    input_map = options['H:/Shared_data/test1.tif']
    output_map = options['Test_24']
This is bogus. The keys in the "options" dictionary are the names of
the options defined in the g.parser comments (assuming that you have
them; if you don't, grass.parser() won't work).
to implement it.
  File "test.py", line 18, in <module>
  File "F:\GRASS-6-SVN\etc\python\grass\script\core.py", line 359, in parser
    os.execvp("g.parser.exe", [name] + argv)
  File "F:\Quantum GIS\python\os.py", line 353, in execvp
  File "F:\Quantum GIS\python\os.py", line 389, in _execvpe
I have no idea what's causing this.
I suggest modifying the parser() function to print the arguments which
are being passed to os.execvp():
Dear All,
Thank you very much for all your inputs and you guys have done a wonderful work.
I am able to solve my problem.
Three Cheers for Grass and Open Source Softwares.
Thanks you all once again.
With Regards,
Bishwarup
On Thu, Mar 25, 2010 at 7:50 AM, Glynn Clements <glynn@gclements.plus.com> wrote:
This should be:
or:
def main():
This is bogus. The keys in the “options” dictionary are the names of
them; if you don’t, grass.parser() won’t work).
to implement it.
I have no idea what’s causing this.
