[GRASS-dev] How can I cange or modify the GUI for watershed analysis?
Dear frnd,
I am not getting “-interface-description”.
Please suggest me how can i get gui.xml?
sandip
On Mon, Nov 14, 2011 at 8:16 PM, Markus Neteler <neteler@osgeo.org> wrote:
(please keep messages on the list)
With --interface-description you get the XML description of the modul.e
This you can parse and then develop your own GUI.
On Mon, Nov 14, 2011 at 1:00 PM, Sandip Maity <sandip.stesalit@gmail.com> wrote:
Dear frnd
I am planning to change in GUI for watershed basin analysis.
Actually, the GUI asking to many data’s and seems to be complicated to non
technical person. I want to fixed the parameter to make easy to handle this
valuable software…
please help me.
thanking for your reply and waiting for more suggestion.
sandip
On Mon, Nov 14, 2011 at 3:37 AM, Markus Neteler <neteler@osgeo.org> wrote:
On Fri, Nov 11, 2011 at 12:37 PM, Sandip Maity
Dear sir,
I want to modify the existing code of watershed analysis.
Please tell me in which file or folder i should go for changing the
code?
I have to change some or modify the form structure.
Please explain what you mean with “form structure”.
In the sense of DEM or in the sense of graphical user interface?
2011/11/15 Sandip Maity <sandip.stesalit@gmail.com>:
Dear frnd,
I am not getting "-interface-description".
r.watershed --interface-description > gui.xml
ML
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Dear Martin,
I am using WXPYTHON.
So, where I can use this comand “r.watershed–interface-description”
Please help me.
sandip
On Tue, Nov 15, 2011 at 4:26 PM, Martin Landa <landa.martin@gmail.com> wrote:
Dear frnd,
ML
Dear Martin,
So, where I can use this comand "r.watershed--interface-description"
Please help me.
Open a GRASS shell and type:
To create a XML file, type:
Don't forget the space between r.watershed and --interface-description.
In case you want a WPS XML process description to use with PyXB type:
r.watershed --wps-process-description > r_watershed_process.xml
Soeren
sandip
> Dear frnd,
ML
grass-dev mailing list
grass-dev@lists.osgeo.org
Dear Soren,
I have used grass64 -text to run
“r.watershed --wps-process-description > r_watershed_process.xml”
and
“r.watershed --interface-description > gui.xml”
GUI.XML is created but it is the size of zero byte.
please help.
Sandip
2011/11/15 Sören Gebbert <soerengebbert@googlemail.com>
Dear Martin,
Please help me.
Don’t forget the space between r.watershed and --interface-description.
Soeren
sandip
Dear frnd,
ML
Dear Soren,
"r.watershed --wps-process-description > r_watershed_process.xml"
Unfortunately "r.watershed --wps-process-description" only works with grass7.
and
"r.watershed --interface-description > gui.xml"
Can you see the XML content when executing "r.watershed
--interface-description" in the shell?
BTW, you need to use a unix shell like sh or bash to redirect the
output of the command into a file using ">".
What operation system are you using?
Soeren
please help.
Sandip
> Dear Martin,
> Please help me.
Soeren
> sandip
>> > Dear frnd,
>> ML
Dear soren,
I am using windows xp.
sandip
Dear Soren,
Unfortunately “r.watershed --wps-process-description” only works with grass7.
and
Can you see the XML content when executing “r.watershed
–interface-description” in the shell?
output of the command into a file using “>”.
Soeren
please help.
Sandip
Dear Martin,
Please help me.
Soeren
sandip
Dear frnd,
ML
Hi Sandip,
i can't help you in this case. I think Google is your friend to figure
out howto redirect the output of r.watershed --interface-description
into a XML file on the command line.
I'm not sure but maybe the QGIS-GRASS package (www.qgis.org) has a
unix shell included?
You can also try to implement a Python script using subprocess and
stdout fetching to get the XML content when calling r.watershed? As
you already use WXPYTHON this should be no problem? Just make sure the
Python script is executed in the GRASS environment.
Best
Soeren
Dear soren,
sandip
> Dear Soren,
grass7.
> and
Soeren
> please help.
> Sandip
>> > Dear Martin,
>> > Please help me.
>> Soeren
>> > sandip
>> >> > Dear frnd,
>> >> ML
>> > _______________________________________________
