[GRASS-dev] How GRASS should behave when another session is already active?
I need opinions on how to resolve the question whether GRASS session can be started from another GRASS session.
Here we want to use GISBASE from environment instead of build constant if available:
https://trac.osgeo.org/grass/changeset/45576
However, here we cause error when GISBASE already exists:
http://trac.osgeo.org/grass/changeset/59210
But the check was removed in:
http://trac.osgeo.org/grass/changeset/59220
because of:
http://trac.osgeo.org/grass/ticket/2213
The point of r59210 was to make impossible to start another GRASS session within an existing session. However, r45576 is using exactly same check (GISBASE in env) to see if GISBASE is forced from outside. The two places for it are here:
https://trac.osgeo.org/grass/browser/grass/trunk/lib/init/grass.py?annotate=blame&rev=65348#L48
https://trac.osgeo.org/grass/browser/grass/trunk/lib/init/grass.py?annotate=blame&rev=65348#L1633
I think starting non-interactive session (batch/exec mode) should be possible. Perhaps interactive session (–text & --gui) should have the check.
If the check is present (even just for the interactive sessions), the OSGeo4W version (and probably standalone winGRASS too) is going to break (needs to be changed somehow). Moreover, this would disallow setting some GISBASE to system for scripting purposes (“without starting explictly”) and then starting a standard session.
The issue with the current state is that you cannot run different version of GRASS from a current session. More serious issue is that you cannot start another version if you have GISBASE in your system environment for scripting purposes (as mentioned above). The current behavior may also differ depending on a platform.
I’m not really sure what were the original intentions but I would prefer to switch the logic in r45576 and use GISBASE only if the path from compile time does not exist. This allows to override current session (GISBASE set in some way) but allows to supply the GISBASE when there is something wrong with compile time path. I would use some advice because I don’t know how this works on Windows and Mac nor what grass.sh file is supposed to do.
Vaclav
On Tue, Jun 2, 2015 at 3:05 AM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
possible.
Maybe yes.
Perhaps interactive session (--text & --gui) should have the
check.
Definitely. IMHO there is no point in starting GRASS GIS as
interactive session from within GRASS - only asking for troubles. Or
is there any use case where this makes sense?
Why does the OSGeo4W break? This is not clear to me.
GISBASE to system for scripting purposes ("without starting explictly") and
.. you mean in the non-interactive case.
... yes, luckily :slight_smile:
Cannot we suggest to the user via test to remove that variable? Rather
than overriding it?
I'm not really sure what were the original intentions but I would prefer to
with compile time path. I would use some advice because I don't know how
I cannot comment yet on this unless I fully understand the issue (see
questions above).
Probably the pseudo-code should go into a trac page?
On 02/06/15 03:05, Vaclav Petras wrote:
if available:
because of:
Even though I see this happen regularly amongst my students, I'm not sure that I consider this such a problem to justify significantly changing the existing logic. Have you come across any serious issues related to this ?
The whole notion of a "session" is a bit misleading as all a "session" is (IIUC) is a specific state of environment variables. So if someone wants to switch GRASS version during a working session, this should remain possible by just changing these environment variables, i.e. after having launched trunk, switch to the grass70 release branch:
export GISBASE=/data/home/mlennert/SRC/GRASS/grass70_release/dist.x86_64-unknown-linux-gnu/
export LD_LIBRARY_PATH=/data/home/mlennert/SRC/GRASS/grass70_release/dist.x86_64-unknown-linux-gnu/lib/
export PATH=/data/home/mlennert/SRC/GRASS/grass70_release/dist.x86_64-unknown-linux-gnu/bin/:/data/home/mlennert/SRC/GRASS/grass70_release/dist.x86_64-unknown-linux-gnu/scripts/:/home/mlennert/.grass7/addons/bin:/home/mlennert/.grass7/addons/scripts:/home/mlennert/.grass7/addons/:/home/mlennert/BIN:/home/mlennert/BIN:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games:/opt/libreoffice/program:/home/mlennert/SRC/FWTools-2.0.6/bin_safe
or similar (there might be some other variables that need to be changed).
Why should this be bad ? But I see your argument that (in this case) the grass70 starting (better name would be "env_setup") script should actually force setting the GISBASE (and the others) to the path where grass70 is installed, instead of taking the existing setting from the environment, thus allowing easy switching of versions.
possible. Perhaps interactive session (--text & --gui) should have the
check.
Non interactive sessions should always be possible since you can set all the env variables in the script and IIUC these will only be valid during the execution of the script.
IIRC, this is just due to the check being in grass.py, but wingrass setting the env variable in the bat startup script.
some GISBASE to system for scripting purposes ("without starting
explictly") and then starting a standard session.
AFAIU, you can. You just have to set the env variables correctly.
If you don't want to have this problem, just don't set a system-wide / user-session wide GISBASE. You can always set it explicitely in your scripts.
The current
This would mean as I said above that calling the "starting" script of a specific version would always by default set the relevant variables to that version. I can agree to that.
You mean that we would have some fallback mechanism allowing to overwrite the default from the command line (i.e. something like this: grass70 --use-env-variables) ?
I think this discussion is relevant, but please do not go through any premature changes before we haven't thought this through.
Moritz
check.
I cannot think of any but the issue might be how do we recognize we are in a session versus somebody just have some variables set in system environment and wishes to start GRASS in a regular way. Perhaps using GISRC rather then GISBASE to see if we are in a session?
Well, that’s the part I’m not sure about. From the commits it seems that OSGeo4W sets GISBASE ahead because the compile time path recored in grass.py is wrong.
You can see GISBASE=%OSGEO4W_ROOT%\apps\grass\grass-@VERSION@ in:
https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/osgeo4w/env.bat.tmpl
Although there is nothing with GISBASE in:
https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/env.bat
Perhaps forcing different GISBASE should be done using different variable such as GRASS_GISBASE? GISBASE would mean GISBASE of currently running session. GRASS_GISBASE would mean I wish to use use this path as GISBASE next time I start GRASS session. But I’m not sure if I like it. It could mess up the script on MS Windows a lot.
… you mean in the non-interactive case.
No, I mean setting GISBASE into my system for convenient writing of scripts which use “without starting explicitly” paradigm and then starting standard session, interactive (–text, --gui) or non-interactive (–exec, GRASS_BATCH_JOB). Any check for GISBASE as a proof of already running session would disallow starting an actual session in this case (at least in interactive mode if check is implemented only for the interactive mode). Again, perhaps checking for GISRC rather then GISBASE is the way out.
Note that putting the variable into system environment is advantageous for the scripts because it leads to scripts without hardcoded paths which can be moved from machine to another. A lot of software, such as Java requires you to set some environmental variables to enable using in command line or in general.
However, in case of GRASS we can say that the best practive is to but the executable on path and query executable for GISBASE (which is for example needed for PYTHONPATH which is needed for import grass.script which is needed for setup.init call).
… yes, luckily :slight_smile:
than overriding it?
Currently, as far as I understand, we are actually overriding it with OSGeo4W (in the bat script, not grass.py which then uses it). On Linux, it will be used. The warning would be always present with OSGeo4W.
Asking user to remove the variable would also mean that you would have to put that to your scripts (which use “without starting explicitly” paradigm). So maybe you wouldn’t be required to set GISBASE but you would have to delete it. This goes against my ultimate goal which is to make “using GRASS modules from outside” easier.
But then again, perhaps the problem is that we check for a wrong variable. I will try to discuss it more in answer to Moritz.
questions above).
grass.py now has (pseudo-code):
if GISBASE in environment:
current_gisbase = GISBASE path from environment
else:
current_gisbase = GISBASE path set at compile time
According to mentioned commits and the env.bat.tmpl file it seems that OSGeo4W goes to the first case because the compile time path is wrong. Unfortunately, also in case of having GISBASE set in system to have it at hand (as some people do on Linux), the first case applies and you many end up in different version of GRASS then intended (GISBASE points to stable release but you explicitly started trunk).
I suggested using GISBASE from environment as fallback:
if current_gisbase does not exist:
But I’m not sure how reliable “current_gisbase does not exist” could be.
In this email I also suggested GRASS_GISBASE variable:
if GRASS_GISBASE in environment:
current_gisbase = GRASS_GISBASE path from environment
else:
This would nicely solve the OSGeo4W case (special variable for a special case), but I’m afraid it could also complicate the scripts (but perhaps not?).
On Tue, Jun 2, 2015 at 7:50 AM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
if available:
because of:
Interesting. I actually haven’t seen it in this way. I’m concerned about scripting, other applications and advanced users.
I’m not sure that I consider this such a problem to justify significantly changing the existing logic.
… and apparently it is not trivial (r59210 and r59220).
I don’t know about any problems and even the commit r59210 which did the check and failed with present GISBASE doesn’t disclose any motivation. Maybe Martin remembers… Markus is saying that it is asking for trouble. Perhaps, but on the other hand, a new session overrides a lot of variables and surely allows to at least use different data (but MANPATH and PYTHONPATH should be OK too). But also, there is a lot of variables which are not overridden (e.g. GRASS_HTML_BROWSER which is OK, but also discussed GISBASE which is a catastrophe if the version/installation is different).
The whole notion of a “session” is a bit misleading as all a “session” is (IIUC) is a specific state of environment variables.
You are right that whole notion of a “session” is a mess. GRASS session has two parts.
First, runtime environment for modules which is a set of variables such as PATH, LD_LIBRARY_PATH or PYTHONPATH.
Second, data linked using GISRC file and variable. In a GRASS session, data, specifically Mapset, is locked to prevent other GRASS sessions from modifying it. There is a “gisrc” file somewhere which contains information about current GRASS Database directory, Location and Mapset (basically full path to mapset) and optionally other variables. Path to this file is stored in GISRC variable and it does not change during the GRASS session, although subprocess may change GISRC variable to do some special things (e.g. Mapset-based parallelization).
GRASS session by itself can change which data (Mapset) are linked/connected but it cannot (should not) change the GISRC variable (“gisrc” file path). Runtime environment cannot be changed by the session itself which is both technical and design limitation.
If one just sets up the required variables, there is not locking of the Mapset nor cleaning of temporary directory in a Mapset (other managed temporary file is for example “gisrc” file). GRASS session can be understood as a process which starts and ends with all these steps besides providing the right environment.
Then perhaps it seems that we can allow having runtime environment in the system all the time and the only thing where we may (or may not) need to limit nesting is a fully working environment which means that GISRC environment variable is present. But the latter test also does have to be present unless we want to really ban interactive session in another session.
This would leave use just with the issue of getting GISBASE in case of OSGeo4W.
Why should this be bad ? But I see your argument that (in this case) the grass70 starting (better name would be “env_setup”) script should actually force setting the GISBASE (and the others) to the path where grass70 is installed, instead of taking the existing setting from the environment, thus allowing easy switching of versions.
Exactly, but OSGeo4W requires setting of GISBASE from outside because GISBASE from compilation is wrong. I’m not sure if this is possible on some other platforms or if there is some other way around than setting a variable.
I still can see only two possible solutions. Use GRASS_GISBASE (or whatever name) variable when present in cases that the distribution cannot ensure the right path in grass.py. GRASS_GISBASE would be used only in a distribution custom script which subsequently invokes grass.py. I hope that GRASS_GISBASE wouldn’t be used in scripts because the need for it would be already satisfied in whatever is behind grass7 command (which should be used in the scripts instead or with the actual GISBASE).
The second solution is to use existing GISBASE variable as a fallback when the path from compile time does not exist. I’m not sure how reliable this can be tested. Is it possible that the directly will exist but is unusable (and user indeed wants to use the existing GISBASE) or there are some strange permission issues and it would say it does not exist just because we cannot write there or something? Pseudo-code for both solutions is in my previous email to Markus.
check.
By non-interactive session I mean an actual run of grass7 command* but without jumping to the command line. This can be now achieved by --exec or BATCH_MODE. Perhaps interactive is not a right word since you can actually start GUI using the --exec flag, so what you need and then close it. The difference is in the presence of a prompt and execution of a process specified when starting the session.
Manual setting of the environment with or without the help of grass.script.setup.init function should be always possible. However, I think it is a pain and I would like to see it replaced by usage of “grass71 --exec” interface as it is easier, safer and more reliable (e.g. locking, ctypes works). However, I also see that changing the environment directly in the script has it’s advantages, most importantly you can use grass.script interface without creating another file, so I’m also trying to simplify, or at least not complicate, this procedure.
  • I really wonder how should I call that. I would like to see all distributions to use just grass, so one don’t have to think if it is 70 or 71 and write specific number only if necessary (like with Python). And it is a command, program or an app?
I think that the bat script just calls the grass.py file:
https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/osgeo4w/grass.bat.tmpl
If we don’t check for existing session using GISBASE or we use one of the solutions above for getting the right GISBASE. there should be no problem.
If we would use GISBASE to check for an existing session, you wouldn’t be able to put GISBASE to your system environment and then start GRASS using grass7 command. If check applied also for --exec, you would have to unset GISBASE in any script which would use --exec and which should be portable. This would complicate the manual setup which is not acceptable.
If you don’t want to have this problem, just don’t set a system-wide / user-session wide GISBASE. You can always set it explicitely in your scripts.
True, but there are people who want to use GRASS modules directly in the command line and I also don’t want to have complicated scripts with a lot of hardcoded paths (preferably no hardcoded paths). The alternative for scripts is to have grass7 command/program on path and then get GISBASE from it. I like that but I think that it is still quite long which may be the reason why I haven’t seen it used much. The other reason might be that grass is not on path on MS Windows by default, nor is the possibility advertised in doc/wiki such as here:
http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
The current
This would mean as I said above that calling the “starting” script of a specific version would always by default set the relevant variables to that version. I can agree to that.
Yes, we even already have it but because of usage of GISBASE variable there is great potential for problems as discussed above. I now suggest that either invalid GISBASE from compile time or presence of another variable (e.g. GRASS_GISBASE) would use it. However, I’m not sure what are the issues with either of these solutions. I wonder if there is some other solution (like no GISBASE path from compilation, better distribution/install process, …). The solution with a parameter (–use-env-variables or --gisbase “/the/path”) also crossed my mind and there already was a similar interface for Location and Mapset (to --use-env-variables) but it seems to me that environmental variable is more appropriate interface in this case considering the use cases (distribution, system-driven invocation) as opposed to user/programmer interface which should be as clean as possible (and --gisbase “/the/path” is not nice, even just in --help doc).
If environmental variable has a special name (such as GRASS_GIS which does not overlap with in-session name), there is no need for --use-env-variables but this kind of parameter could be helpful when you would like to use GRASS default for GRASS_HTML_BROWSER although you have something set in the system but I don’t think that this useful (and if you need it then I think is OK to do things like unset the variable).
The fallback is need for OSGeo4W and perhaps other distributions as the actual (runtime) path may not be known during compilation.
I think this discussion is relevant, but please do not go through any premature changes before we haven’t thought this through.
This is my intention exactly. Thanks for the comments so far, it was very helpful for me in sorting out things and thinking about solutions. There is a lot of moving peaces. I also believe that I cleaned up grass.py significantly, so I invite anybody who is interested to examine actual code and commend on it.
Vaclav
