[GRASS-dev] how to add metadata in a raster file?
Hello,
while modifying a Landsat7 import module to read data from the .met
(metadata) file,
i wondered how i could store some of this useful information as
appendix to the raster layer created.
What is the way to do that in C?
thanks,
Yann
(metadata) file,
yes, but it is a quite limitted. (40 lines x 80 columns for comments section)
from the command line you can use "r.support title=" to set a title,
and "r.support comment=" to add a comment. This is viewable with r.info.
In C it is done with the History struct, see lib/gis/history.c
see any number of raster modules that output a map, e.g. r.in.xyz:
  /* close raster file & write history */
  G_close_cell(out_fd);
  G_short_history(outmap, "raster", &history); /* init hist structure */
  G_command_history(&history); /* wrote command line to comments */
  strncpy(history.datsrc_1, infile, RECORD_LEN); /* fill in data source line */
  history.datsrc_1[RECORD_LEN-1] = '\0'; /* strncpy() doesn't null terminate if maxfill */
  G_write_history(outmap, &history); /* write hist structure to disk */
you need to do this *after* you've already closed the map, and then pass
the hist fns the string containing the map name.
Hamish
