[GRASS-dev] how to apply a processing to a group?
was wondering...
Say somebody imports a hyperspectral/hypertemporal image (i.e. AVIRIS
/ Modis8days comp for 2-3 years) and wants to process all the bands
simultaneously.
Simpler(?)
Is there a way to apply a simple set of equations to the group itself,
bands belonging to the group would then inherit the equations.
More complicated (maybe?)
is there a way to select a root name (say modis_ref_2* and
modis_ref_1*) and apply a beloved NDVI to the the pair matching
extensions.
is there a way to use group directly for display? (i.e. d.rast
group_name=blabla mode=rgb combination=4,2,1).
thanks,
Yann
simultaneously.
[Markus?]
Simpler(?)
Not much outside the imagery modules will do that right now, AFAIK.
It would be nice if more raster modules could take advantage of i.group
groups. (maybe just a script that does bash loop below)
extensions.
Use g.mlist + a shell loop:
for MAP in `g.mlist pat=modis_ref_2*` ; do
  echo "Processing [$MAP] ..."
  r.info -r $MAP
done
d.rgb r= g= b=
Hamish
