Michael Barton wrote:
I¹ve created a nice TclTk panel for d.text.new in the GIS Manager. It works
fine. Now I¹d like to be able to change the fonts it uses. Currently, it
only seems to use romans.
I¹ve taken out the hard coded d.font romans from the gis.m display routine
as it seems to be no longer needed with the new drivers.
But still, when I run d.font (which requires an x.mon to run) and
d.font.freetype, it has no effects on d.text.new. I want to embed font
selection in the d.text.new panel but want to make sure it works and see
what format of fonts definitions it will accept.
Do you have any idea why changing the fonts doesn¹t have any effects on
d.text.new?
d.font and d.font.freetype don't work with direct rendering, as there
is no monitor process to retain state between d.* commands; each d.*
command runs as if with a freshly-started monitor. Similarly, d.frame
and d.save don't work, for the same reason.
To set the default font for direct rendering, you have to use the
environment variables:
GRASS_FT_FONT
GRASS_FT_ENCODING
GRASS_FONT
Note that GRASS_FONT accepts either FreeType or stroke fonts, while
GRASS_FT_FONT only accepts FreeType fonts. If both are set,
GRASS_FT_FONT takes precedence over GRASS_FONT. If neither are set,
"romans" is used.
For GRASS_FONT, the value is passed directly to R_font(), and should
be one of:
1. The full path to a stroke font, beginning with $GISBASE/fonts.
2. The full path to a FreeType font (.ttf file).
3. The name of a FreeType font from the freetypecap file.
4. The name of a stroke font in the $GISBASE/fonts directory.
If the value begins with a "/", it's a full path. If it begins with
(the expansion of) $GISBASE/fonts, it's assumed to be a stroke font,
otherwise a freetype font.
If the value doesn't begin with a "/", it's first searched for in the
freetypecap file; if it isn't found, it's assumed to be the name of a
stroke font.
