[GRASS-dev] How to compile a script in GRASS
Greetings
I have GRASS script and I want to compile it in Linux.
I have used other files (like r.example) as an example and when I try to run it like (e.g. r.example)
cd r.example
make
I get:
Makefile:5: …/…/include/Make/Script.make: No such file or directory
make: *** No rule to make target `…/…/include/Make/Script.make’. Stop.
Why am I missing? I have GRASS6.4.1 installed.
Thanks
Luisa
On Fri, Oct 21, 2011 at 5:31 PM, Luisa Peña <luisapena1979@gmail.com> wrote:
Greetings
cd r.example
make
I get:
Makefile:5: ../../include/Make/Script.make: No such file or directory
make: *** No rule to make target `../../include/Make/Script.make'. Stop.
You need to
- either also install the grass-dev(el) package
- or configure the source code and compile at least the
  libraries
Greetings
I have installed GRASS 6.4.1 from ELGIS.argeo repository (grass.x86_64) and installed. Also I have installed grass-devel package fromt he same repository. What is not correc in this?
Or at least, can anyone point me where can I get all steps of this procedure?
Thanks
Luisa
2011/10/22 Markus Neteler <neteler@osgeo.org>
Greetings
cd r.example
make
I get:
You need to
  • either also install the grass-dev(el) package
  • or configure the source code and compile at least the
    libraries
On Mon, Oct 24, 2011 at 10:27 AM, Luisa Peña <luisapena1979@gmail.com> wrote:
Greetings
Yes it is. The question where your module is stored. If it is outside
the GRASS source code directory then you need to tell "make" where
to find it.
# adapt path to your system:
make MODULE_TOPDIR=/usr/lib64/grass641/
Hope this helps
On Mon, Oct 24, 2011 at 1:11 PM, Luisa Peña <luisapena1979@gmail.com> wrote:
Hi Markus
(please keep it on the list)
I have tried
... what? need to know it.
Does
/usr/lib64/grass-6.4.1/include/Make/
exist?
and I got:
Makefile:5: /usr/lib64/grass-6.4.1/include/Make/Script.make: No such file or
directory
`/usr/lib64/grass-6.4.1/include/Make/Script.make'. Stop.
The thing is that there is no Include/Make in my GRASS folder. But I have
installed grass+libs+devel packages
2011/10/24 Markus Neteler <neteler@osgeo.org>
wrote:
> Greetings
> and
to find it.
Hope this helps
I have tried your suggestion
sudo make MODULE_TOPDIR=/usr/lib64/grass641/
No… That folder does not exist
Hi Markus
I have tried
… what? need to know it.
Does
exist?
and I got:
directory
`/usr/lib64/grass-6.4.1/include/Make/Script.make’. Stop.
wrote:
Greetings
and
the GRASS source code directory then you need to tell “make” where
to find it.
Hope this helps
No.. That folder does not exist
so, then please check where the folder is... I don't know the
packaging scheme of your Linux distro.
