As a start to fixing the currently broken table and column select combo boxes in the wxPython GUI, is there some way to find out what the current working setting is for the database driver and database (i.e., path)?
Michael
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
(i.e., path)?
The defaults can be obtained with "db.connect -p", while the
parameters used by a specific vector map can be obtained with
"v.db.connect -g".
lib/python/grass.py has interfaces to both of these:
def db_connection():
"""Return the current database connection parameters
(interface to `db.connect -p').
returns a dictionary:
kv = grass.db_connection()
database = kv['database']
driver = kv['driver']
while:
def vector_db(map, layer = None, **args):
"""Return the database connection details for a vector map
(interface to `v.db.connect -g').
returns either a list:
f = grass.vector_db(map, layer)
if not f:
grass.fatal("An error occured while running v.db.connect")
layr = f[0]
table = f[1]
keycol = f[2]
database = f[3]
driver = f[4]
or a list of such lists if the "layer" argument is omitted.
Note: if you intend to parse the output from "v.db.connect -g"
yourself, use the (recently-added) fs= option. The default field
separator is a space, but the database may be a pathname, which might
contain spaces, particularly on Windows.
