Beyond r.param.scale, is there a good method anyone knows of to find peaks or hilltops? I'm more interested in the tops of hills/high points than the single cell that is the highest.
Thanks
Michael
____________________
C. Michael Barton
Arizona State University
Thanks
Michael
The r.param.scale uses some common cuttoffs for curvatures to define features.
A geomorphic classification may accomplish what you are looking for, i.e.
generate some training areas that define 'summits', through in several
terrain-shape indices, and then run a supervised classification. Unsupervised
classification can sometimes work well for this kind of task, however it is
data-driven and results can vary from location to location.
Dylan
C. Michael Barton
On Wed, Nov 18, 2009 at 10:22 PM, Michael Barton <michael.barton@asu.edu> wrote:
Some friends and I had a similar problem once. We had to find hilltops
because, according to brazilian environmental legislation, they are
environmental preserves. (Top 1/3 of the mountain / hill has to be
preserved)
The way it was done to solve this was to define watersheds on an
__inverted__ DEM
Basically, once we invert the DEM, the sinks will be your peak. The
watershed area will be your mountain / hill "influence zone". The
highest and lowest elevation inside each watershed, are the hill top
and bottom elevation. The preserved area in each mountain was
everything above the 2/3 limit (top - (top-bottom)/3).
There were some other things we considered, like maximum slope but,
the basic idea was to just invert the DEM and work with watersheds...
Daniel
PS - The entire procedure was done in another commercial GIS software
but I'm sure it can easily be done in Grass
because, according to Brazilian environmental legislation, they are
preserved)
Daniel,
Does this mean that the bottom 2/3 can be mined as long as the top 1/3 is
preserved? Interesting idea.
Michael
C. Michael Barton
preserved)
__inverted__ DEM
Daniel
Well, it's not as straight forward as that. The preservation areas are
more for land cover changes and such. There is a specific part in the
legislation which states that "activities with no locational
alternatives" like mining, can occur in hill tops. There is also a
part about watershed divides (only big formations, not small divides)
The legislation is a bit complicated and filled with controversy!
After all, how do you find the hill / mountain bottom in order to
calculate the top 1/3? The environmental agencies wants the botton to
be as low as possible. The agriculture / forestry lobby wants to push
it up (they always talk about the first saddle point...). Furthermore,
the law defines what are mountains and hills. But that is not a
consensus also... That's one of the many reasons why the entire
brazilian environmental legislation is under "attack" (ops, I should
say revision)...
This is a very complicated issue that I, somehow, got involved in. But
once it became too political, I moved away from the discussions. But
if you are curious about it, fell free to ask
Daniel
On Wed, Nov 18, 2009 at 9:18 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
preserved)
Daniel,
