[GRASS-dev] How to import from a spatialite/sqlite db by v.in.ogr?
database can be downloaded here:
http://www.eea.europa.eu/data-and-maps/data/biogeographical-regions-europe-3
ogrinfo -al -so BiogeoRegions2016.sqlite
INFO: Open of `BiogeoRegions2016.sqlite'
      using driver `SQLite' successful.
Layer name: biogeoregions2016
Geometry: Multi Polygon
Feature Count: 12
Extent: (943611.000000, 600000.000000) - (8500000.000000, 7800000.000000)
Layer SRS WKT:
PROJCS["ETRS89 / LAEA Europe",
    GEOGCS["ETRS89",
        DATUM["European_Terrestrial_Reference_System_1989",
            SPHEROID["GRS 1980",6378137,298.257222101,
                AUTHORITY["EPSG","7019"]],
            TOWGS84[0,0,0,0,0,0,0],
            AUTHORITY["EPSG","6258"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.0174532925199433,
            AUTHORITY["EPSG","9122"]],
        AUTHORITY["EPSG","4258"]],
    PROJECTION["Lambert_Azimuthal_Equal_Area"],
    PARAMETER["latitude_of_center",52],
    PARAMETER["longitude_of_center",10],
    PARAMETER["false_easting",4321000],
    PARAMETER["false_northing",3210000],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","3035"]]
FID Column = PK_UID
Geometry Column = geometry
short_name: String (0.0)
pre_2012: String (0.0)
code: String (0.0)
test which layer are in the db:
v.in.ogr -l input=BiogeoRegions2016.sqlite
biogeoregions2016
Data source <BiogeoRegions2016.sqlite> (format 'SQLite') contains 1 layers:
a layer can be seen by v.in.ogr (see the messed output)
then try to import:
v.in.ogr input=BiogeoRegions2016.sqlite layer=biogeoregions2016|geometry
output=test where=short_name = 'alpine'
ERROR: Layer <biogeoregions2016^^^|geometry> not available
it seems the geometry column of the can't be found by v.in.ogr.
but trying:
ogr2ogr -where "short_name = 'alpine'" test.shp BiogeoRegions2016.sqlite
works without any problems.
tested with
System Info
GRASS version: 7.3.svn
GRASS SVN revision: r70874M
Build date: 2017-04-15
Build platform: x86_64-w64-mingw32
GDAL: 2.1.3
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
any ideas?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-import-from-a-spatialite-sqlite-db-by-v-in-ogr-tp5317435.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
2017-04-16 22:40 GMT+02:00 Helmut Kudrnovsky <hellik@web.de>:
biogeoregions2016
why not
? Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Martin Landa wrote
2017-04-16 22:40 GMT+02:00 Helmut Kudrnovsky &lt;
hellik@
&gt;:
biogeoregions2016
Data source
ERROR: Layer &lt;biogeoregions2016^^^|geometry&gt; not available
why not
as it seems to be (auto-)generated by v.in.ogr(-GUI)?
just filled in the GUI, then pressed run and that's the output ...
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-import-from-a-spatialite-sqlite-db-by-v-in-ogr-tp5317435p5317437.html
Martin Landa wrote
hellik@
&gt;:
biogeoregions2016
Data source
why not
yes, the bioregions2016|geometry is autogenerated by the v.in.ogr-GUI!
tested the cmd on the command line without "|geometry"
C:\>v.in.ogr input=BiogeoRegions2016.sqlite layer=biogeoregions2016
output=testoncmdline where="short_name = 'alpine'"
Check if OGR layer <biogeoregions2016> contains polygons...
100%
WARNING: Width for column short_name set to 255 (was not specified by OGR),
         some strings may be truncated!
WARNING: Width for column pre_2012 set to 255 (was not specified by OGR),
WARNING: Width for column code set to 255 (was not specified by OGR), some
WARNING: Width for column name set to 255 (was not specified by OGR), some
Importing 1 features (OGR layer <biogeoregions2016>)...
100%
Registering primitives...
27 primitives registered
48947 vertices registered
Number of nodes: 27
Number of primitives: 27
Number of points: 0
Number of lines: 0
Number of boundaries: 27
Number of centroids: 0
Number of areas: -
Number of isles: -
Cleaning polygons
Breaking polygons...
Breaking polygons (pass 1: select break points)...
100%
Breaking polygons (pass 2: break at selected points)...
100%
Removing duplicates...
100%
Breaking boundaries...
100%
100%
Cleaning boundaries at nodes...
100%
Merging boundaries...
100%
Removing dangles...
100%
Building areas...
100%
27 areas built
27 isles built
Number of nodes: 27
Number of points: 0
Number of lines: 0
Number of areas: 27
Number of isles: 27
Removing bridges...
100%
Building areas...
100%
27 areas built
27 isles built
Attaching islands...
100%
Number of nodes: 27
Number of points: 0
Number of lines: 0
Number of areas: 27
Number of isles: 27
Finding centroids for OGR layer <biogeoregions2016>...
100%
Writing centroids...
100%
27 input polygons
Total area: 9.48235E+011 (27 areas)
Copying features...
100%
Building topology for vector map <testoncmdline@vecdata>...
54 primitives registered
48974 vertices registered
Building areas...
100%
27 areas built
27 isles built
100%
Attaching centroids...
100%
Number of nodes: 27
Number of primitives: 54
Number of points: 0
Number of lines: 0
Number of centroids: 27
Number of areas: 27
Number of isles: 27
it's imported correctly.
it's a GUI regression.
should I open a ticket?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-import-from-a-spatialite-sqlite-db-by-v-in-ogr-tp5317435p5317439.html
ticket opened by https://trac.osgeo.org/grass/ticket/3333
3333 .... nice number :wink:
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-import-from-a-spatialite-sqlite-db-by-v-in-ogr-tp5317435p5317443.html
Martin Landa wrote
hellik@
&gt;:
biogeoregions2016
Data source
why not
? Ma
Martin Landa
grass-dev mailing list
grass-dev@.osgeo
https://lists.osgeo.org/mailman/listinfo/grass-dev
The more complete bug report is in:
https://trac.osgeo.org/grass/ticket/3308
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-import-from-a-spatialite-sqlite-db-by-v-in-ogr-tp5317435p5317469.html
