r.in_gdal(input="/home/user/geodaten/ASTGTM2_N50E007_dem.tif",output="dem_nrw",flags="e",overwrite="OVR")
File
"/home/user/source/grass-7.4.svn/dist.x86_64-pc-linux-gnu/etc/python/grass/pygrass/modules/interface/module.py",
line 647, in __call__
self.check()
File
line 705, in check
if flg and flg.suppress_required:
TypeError: __nonzero__ should return bool or int, returned str
This script was written by a PyGRASS newcomer who reused code from the
Wiki. The reason for the error is
overwrite="OVR"
which is incorrect (must be: overwrite=True or =False).
The related code is around l705 in
lib/python/pygrass/modules/interface/module.py
def check(self):
"""Check the correctness of the provide parameters"""
required = True
for flg in self.flags.values():
required = False
Could a python expert here please suggest how to generate a more
reasonable error message?
File
self.check()
File
line 705, in check
overwrite="OVR"
Even like that, the error message is informative. It expects a boolean
(True or False) or an integer (say: 0 or 1). Instead a string was returned.
Nikos
def check(self):
required = True
required = False
line 705, in check
Right. My point is that it does not say _which_ flag is wrong.
My scope it to make it easy/obvious also for newcomers...
line 705, in check
Flags are set/updated during the following piece of code (in `module.py`):
# set/update args
for param, arg in zip(self.params_list, args):
param.value = arg
for key, val in kargs.items():
if key in self.inputs:
self.inputs[key].value = val
elif key in self.outputs:
self.outputs[key].value = val
elif key in self.flags:
# we need to add this, because some parameters (overwrite,
# verbose and quiet) work like parameters
self.flags[key].value = val
else:
raise ParameterError('%s is not a valid parameter.' % key)
and `check()`ing for required parameters, runs after when/if the `run_`
attribute is True.
Maybe adding a test before
would help? And report the `flag[key]` in case `val` is not one expected?
Maybe adding a specific test for the overwrite, verbose, quiet parameters, that
exist for every grass module?
