[GRASS-dev] how to start wx vdigit?
On Mar 9, 2008, at 2:16 PM, grass-dev-request@lists.osgeo.org wrote:
Date: Sun, 9 Mar 2008 19:26:39 +0100
Subject: Re: [GRASS-dev] how to start wx vdigit?
To: "William Kyngesburye" <kyngchaos@kyngchaos.com>
Cc: Michael Barton <michael.barton@asu.edu>, GRASS developers list
  <grass-dev@lists.osgeo.org>
Message-ID:
  <f8fe65c40803091126p245b2b7dtd657ceadcfbc5d2a@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
there currently two ways
1) add vector map layer into the layer tree, right click and from
contextual menu choose 'Start editing'
2) select in Map display window toolbar 'Digitize' (the last tool in
the toolbar), then from enabled vdigit toolbar choose vector map layer
you want to edit (this map must be present the current layer tree). I
remember there was bug on Mac connected to wxComboBox inside wxToolbar
instance. So maybe you cannot see these comboboxes in the toolbars.
Then first way should work for you.
Martin
I can't say what William is seeing with OS X 10.5, but with 10.4 and current wxPython binaries, method #2 does not work on a Mac. This is because of a bug in the wxPython code that prevents a control from showing in a menubar using AUI. I reported it to the wxPython/wxWidgets bug list months ago. I just got a message on Friday indicating that this has just been fixed in the wxWidgets source tree. There may also a suggested workaround (that I haven't tried) that involves setting wx.MAC_USE_NATIVE_TOOLBAR=0. I'm not positive it is fixed because this bug report was mixed with another bug. But it seems to be.
Michael
