[GRASS-dev] how to work around "Arument list too long" error in a GRASS python script ?
Hello,
In a python script I have the following call:
grass.run_command('r.series',
                    input = rate_maps,
                    output = sum_rates,
                    method = 'sum',
                    overwrite = True,
                    quiet=True)
rate_maps is a list which in one instance contains 8559 map names, leading to an "OSError: [Errno 7] Argument list too long".
I know that in the shell I could use xargs to work around such a problem. But how to do this in python ?
I could obviously loop through all maps and thus sum them individually, but this just seems horribly inefficient.
Does anyone have a better solution ?
Moritz
* Moritz Lennert <mlennert@club.worldonline.be> [2015-06-11 18:37:36 +0200]:
Hello,
                    input = rate_maps,
                    output = sum_rates,
                    method = 'sum',
                    overwrite = True,
                    quiet=True)
What it the OS limit for it?
- Maybe split in two or three sessions (instead of looping over all)?
- Have you seen this
<https://gist.github.com/max-nova/487a82de00651a33f2c2#file-grass_demo-py-L28&gt;
Nikos
On Thu, Jun 11, 2015 at 12:37 PM, Moritz Lennert <
mlennert@club.worldonline.be> wrote:
Hello,
                   input = rate_maps,
                   output = sum_rates,
                   method = 'sum',
                   overwrite = True,
                   quiet=True)
Moritz
It seems we are hitting these issues quite often, we should consider add
input file as an option like many temporal modules already have. But
splitting as Nikos suggests has the advantage that you can parallelize the
computation.
Anna
grass-dev mailing list
grass-dev@lists.osgeo.org
+1 add input file as an option
On 11-06-15 19:22, Anna Petrášová wrote:
On Thu, Jun 11, 2015 at 12:37 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Hello,
grass.run_command(‘r.series’,
input = rate_maps,
output = sum_rates,
method = ‘sum’,
overwrite = True,
quiet=True)
rate_maps is a list which in one instance contains 8559 map names, leading to an “OSError: [Errno 7] Argument list too long”.
Moritz
It seems we are hitting these issues quite often, we should consider add input file as an option like many temporal modules already have. But splitting as Nikos suggests has the advantage that you can parallelize the computation.
Anna
[grass-dev@lists.osgeo.org](mailto:grass-dev@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-dev](http://lists.osgeo.org/mailman/listinfo/grass-dev)
Hello,
                     input = rate_maps,
                     output = sum_rates,
                     method = 'sum',
                     overwrite = True,
                     quiet=True)
I suppose this is ARG_MAX ?
getconf ARG_MAX
2097152
A text file with all file names only uses 144551 bytes.
Or is there another limit I should look at ?
Yes, thanks, I can do that. I'll also try the file option mentioned by Anna (r.series actually has one). Didn't think of that.
Thanks to both of you !
Moritz
On Thu, Jun 11, 2015 at 1:46 PM, Moritz Lennert <
+0200]:
Hello,
                     input = rate_maps,
                     output = sum_rates,
                     method = 'sum',
                     overwrite = True,
                     quiet=True)
getconf ARG_MAX
2097152
Oh, I didn't know that it already has it. Good to know!
Moritz
        <mailto:mlennert@club.worldonline.be>> [2015-06-11 18:37:36 +0200]:
            Hello,
                                  input = rate_maps,
                                  output = sum_rates,
                                  method = 'sum',
                                  overwrite = True,
                                  quiet=True)
            names,
    getconf ARG_MAX
    2097152
            individually,
        all)?
And, just for info, it solves my problem beautifully.
Moritz
>> input = rate_maps,
>> output = sum_rates,
>> method = 'sum',
>> overwrite = True,
>> quiet=True)
getconf ARG_MAX
2097152
Apparently there's a limit on the maximum length of a single argument,
which appears to be fixed at 128 KiB:
  > subprocess.call(["echo", "x"*131071],stdout=devnull,stderr=devnull)
  0
  > subprocess.call(["echo", "x"*131072],stdout=devnull,stderr=devnull)
[snipped]
This specific issue could be worked around by having
grass.make_command() use multiple arguments when the value is a list,
e.g. "r.series input=map1 input=map2 ...".
But such cases are likely to be problematic on other platforms where
ARG_MAX may be much lower. POSIX only requires that it is at least
4096, and it wasn't so long ago that such a value was commonplace. And
that value includes the environment as well as the command line.
Modules which commonly use many input maps should have the option to
read map names from a file. This mostly affects r.series, which
already does so.
If this issue was more common, we could consider extending G_parser()
to allow transparently reading any option value from a file, using
e.g. input=@filename. But that may just cause similar issues with
--interface-description, G_recreate_command(), etc.
                      input = rate_maps,
                      output = sum_rates,
                      method = 'sum',
                      overwrite = True,
                      quiet=True)
getconf ARG_MAX
2097152
   0
  [snipped]
already does so.
I think that the file option solution is the most adequate. r./v.patch might be potential candidates for that as well.
For the other modules that have such input lists, I doubt that anyone will ever use these with such long lists of maps.
Moritz
On Mon, Jun 15, 2015 at 7:41 AM, Glynn Clements <glynn@gclements.plus.com>
already does so.
Good idea, although I'm afraid of potential problems with interface.
Similar solution, with similar potential issues, is to create automatically
`input_file` when `input` is multiple or when specified in code. Moving
things to parser is definitively more advantageous for things like
overwrite but it may cause some code and reading duplication for Python
scripts.
