[GRASS-dev] html error (access file not found) on compilation of i.landsat.toar in v7
Hello,
I have been able to compile all the i.landsat.toar C code so far in
v7, but it does something strange with the html (old description.html
renamed i.landsat.toar.html in v7).
access: No such file or directory
ERROR: LOCATION <<
       /home/icwater/grass_trunk/dist.x86_64-unknown-linux-gnu/demolocation
       >> not available
make: *** [i.landsat.toar.tmp.html] Error 1
rm i.landsat.toar.tmp.html
What is the reason?
Thank you,
Yann
Yann Chemin
Senior Spatial Hydrologist
www.csu.edu.au/research/icwater
M +61-4-3740 7019
Answering to it, it seems the error does not forbid the code to work
as a module but the manual section is not existing because of that
error.
http://trac.osgeo.org/grass/ticket/1068 mentions about the
access/LOCATION error part.
I should have a look at the html file again, maybe some formating has
changed from v6 to v7.
On 14 October 2010 14:46, Yann Chemin <yann.chemin@gmail.com> wrote:
Hello,
ERROR: LOCATION <<
>> not available
What is the reason?
Thank you,
Yann
Yann Chemin
M +61-4-3740 7019
Yann Chemin
M +61-4-3740 7019
Yann Chemin wrote:
ERROR: LOCATION <<
       >> not available
What is the reason?
I suspect that the installed $GISBASE/demolocation/.grassrc70 file has
GISDBASE pointing to the source tree rather than to the installed
path.
I think that the real-install target in Install.make needs something
like:
  -sed 's#$(GISBASE)#$(INST_DIR)#g' \
    $(GISBASE)/demolocation/.grassrc$(GRASS_VERSION_MAJOR)$(GRASS_VERSION_MINOR) \
    > $(INST_DIR)/demolocation/.grassrc$(GRASS_VERSION_MAJOR)$(GRASS_VERSION_MINOR)
Similar to what is already done for etc/fontcap. We should probably be
doing something similar for Platform.make, although that can be
overridden on the command line when running make.
like:
FWIW, this should be fixed in r43905. The only remaining references to
the source directory should be GRASS_HOME, config.status, comments in
the ctypes wrappers and debug info in binaries.
Actually, you also need r43906, otherwise the g.mapset documentation
uses <srcdir>/dist.<arch>/demolocation as the default database and
location.
Note to developers: *don't* use context-sensitive values for option
defaults unless you have some plan to ensure that the documentation
generated by --html-description isn't bogus.
Glynn wrote:
> -sed 's#$(GISBASE)#$(INST_DIR)#g'\
fwiw, we should rename "demolocation" to "dummylocation" or
similar, as it better describes what it is and why it's there.
Hamish
Thank you Glynn that seems to be resolved,
A last error comes up now:
root@SeeePC:/home/yann/grass_yann/imagery/i.landsat.toar# make
VERSION_NUMBER=7.0.svn
/home/yann/grass_yann/dist.i686-pc-linux-gnu/tools/g.html2man.py
/home/yann/grass_yann/dist.i686-pc-linux-gnu/docs/html/i.landsat.toar.html
/home/yann/grass_yann/dist.i686-pc-linux-gnu/man/man1/i.landsat.toar.1
/home/yann/grass_yann/dist.i686-pc-linux-gnu/docs/html/i.landsat.toar.html:133:0:
Error (IndexError('pop from empty list',)): </p>
make: *** [/home/yann/grass_yann/dist.i686-pc-linux-gnu/man/man1/i.landsat.toar.1]
Error 1
The html file was OK in v6, so I suppose something new came up in that
part too. I tried to look in the file, but nothing seems to flash.
like:
  \-sed &#39;s\#$\(GISBASE\)\#$\(INST\_DIR\)\#g&#39; \\
          $\(GISBASE\)/demolocation/\.grassrc$\(GRASS\_VERSION\_MAJOR\)$\(GRASS\_VERSION\_MINOR\) \\
          &gt; $\(INST\_DIR\)/demolocation/\.grassrc$\(GRASS\_VERSION\_MAJOR\)$\(GRASS\_VERSION\_MINOR\)
location.
Yann Chemin
M +61-4-3740 7019
g.html2man.py requires that the HTML file is structurally valid.
The i.landsat.toar.html file isn't valid; it contains bogus </p> tags.
This appears to arise from the use of <ul>, which is a block element
and thus cannot occur within <p>. The effecti is as if a </p> tag was
inserted immediately before the <ul> tag. The subsequent explicit </p>
tag doesn't match any open <p> tag, resulting in the error.
You can fix the error by adding a <p> tag immediately after the </ul>.
For more information, see the bottom of:
http://grass.osgeo.org/wiki/Updating_GRASS_Documentation
Glynn:
valid.
</p> tags.
should be fixed in r43933
Hamish
