[GRASS-dev] i.landsat.toar clang compilation fails due to inline
i.landsat.toar compilation fails when compiling using clang compiler. The error is:
undefined reference to `date_replace_slash’
This function is defined using inline keyword:
inline void date_replace_slash(char *str)
I know inline is not part of C89. However, I’m not sure about the fix. I can fix it by replacing inline by __inline__. This works for GCC [1] and clang (should support GCC extensions) but I’m not sure about other compilers (on the less usual platforms).
Moreover, I actually don’t know how what causes the error in the first place.
Alternative fixes are macro but I would just do the normal function and hope for compiler optimization.
Note that the function should be probably static.
Vaclav
[1] http://gcc.gnu.org/onlinedocs/gcc/Inline.html
Log:
: && clang -L…/dist.i686-pc-linux-gnu/lib -L…/dist.i686-pc-linux-gnu/lib -Wl,–export-dynamic -Wl,-rpath-link,…/dist.i686-pc-linux-gnu/lib -o …/dist.i686-pc-linux-gnu/bin/i.landsat.toar OBJ.i686-pc-linux-gnu/earth_sun.o OBJ.i686-pc-linux-gnu/landsat.o OBJ.i686-pc-linux-gnu/landsat_met.o OBJ.i686-pc-linux-gnu/landsat_set.o OBJ.i686-pc-linux-gnu/main.o -lgrass_raster.7.0.svn -lgrass_gis.7.0.svn -lm
OBJ.i686-pc-linux-gnu/landsat_met.o: In function lsat_metadata': .../imagery/i.landsat.toar/landsat_met.c:124: undefined reference to date_replace_slash’
…/imagery/i.landsat.toar/landsat_met.c:138: undefined reference to `date_replace_slash’
clang: error: linker command failed with exit code 1 (use -v to see invocation)
On Sun, Oct 20, 2013 at 5:46 AM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
error is:
undefined reference to `date_replace_slash'
This function is defined using ``inline`` keyword:
I know ``inline`` is not part of C89. However, I'm not sure about the fix. I
can fix it by replacing ``inline`` by ``__inline__``. This works for GCC [1]
and clang (should support GCC extensions) but I'm not sure about other
"static" may be a viable solution. For comments on this, see also
http://lists.osgeo.org/pipermail/grass-dev/2013-July/065231.html
Replacing inline by static in r58077.
Fixed according to G7: landsat_met.c:103: undefined reference to `chrncpy’ [2] where the chrncpy from the same file causes the same error and is only static now.
static inline works fine, too, but date_replace_slash does not meet criteria for being inline specified in [2] by Glynn: It is not simple enough (has a loop inside) and moreover, it’s called only a few times (raw guess).
Vaclav
[1] https://trac.osgeo.org/grass/changeset/58077
[2] http://lists.osgeo.org/pipermail/grass-dev/2013-July/065231.html
error is:
“static” may be a viable solution. For comments on this, see also
