[GRASS-dev] i.landsat.toar to be included in Grass7
Hello list,
I would like to include i.landsat.toar in GRASS7.
I believe this will bring the necessary complement to i.atcorr and the
subsequent i.albedo/i.vi/etc that are part of the chain processing of
Landsat.
Is there anybody maintaining it these days?
I would be happy to do the necessary to include it in GRASS 7.
In the future, I would also like to remove from GRASS-ADDONS the
i.dn2* modules that mostly are included into i.landsat.toar but for
the .MTL metadata format of some types of Landsat 5 imagery (I checked
the landsat_met.c in i.landsat.toar and believe it is feasible to
transfer the .MTL parsing code across eventually).
Any vote please,
Thank you,
Yann
Yann Chemin
Senior Spatial Hydrologist
www.csu.edu.au/research/icwater
M +61-4-3740 7019
i.atcorr and the subsequent i.albedo/i.vi/etc that are part
of the chain processing of Landsat.
I'd like to see i.landsat.acca (cloud masks) travel along with
it too.
Yes, Jorge and I have been working on getting it ready recently,
https://trac.osgeo.org/grass/log/grass-addons/imagery/i.landsat.toar
The grass7 patch is out of date now- to avoid wasted work I was
waiting until the grass6 version settled down before recutting
that.
7. In the future, I would also like to remove from
GRASS-ADDONS the i.dn2* modules that mostly are included into
i.landsat.toar but for the .MTL metadata format of some types
of Landsat 5 imagery (I checked the landsat_met.c in
i.landsat.toar and believe it is feasible to transfer the .MTL
as long as functionality is retained and differences between the
output of the two modules are for known reasons, I don't mind
i.dn2* being "merged" into i.landsat.toar. I don't think that
getting the L5 glovis MTL metadata files to read in i.landsat.toar
will be too hard, as the L7 versions of the same work ok already.
The process of making it more robust will take a while though, and
the hardcoded file length stuff in .toar probably has to go away.
thanks,
Hamish
Yann Chemin
www.icwater.org
it too.
+1 for that one too
Do you have a v7 version already ?
Ok will read that one
that.
You mean to include it in v6 too?
If MTL for L7 it should be ok then
I was thinking more about parsing metadata files of other format as
"merging" the modules. The i.dn* are simple dn to rad to reftoa,
nothing i.Landsat.toar cannot do already.
About the fixed length stuff so you have a proposition or should I see
how it comes up along the way?
thanks,
Hamish
Thank you Hamish this sounds really good
