Hi Nikos/devs,
Currently, I am Co-supervising a student who is using i.landsat8.swlst module for his bachelor thesis.
During that work we stumbled upon some minor issues where we would like to propose some changes in the module:
The k-flag does the opposite of what the description tells. It sets the computational region to the Landsat scene. I would say, it is more in line with other GRASS modules if the computational region is not changed by default. So I would rather change the description than the behavior (please find a suggestion in the diff below). However, maybe it is even more coherent with the rest of the GRASS modules if the flag is removed?
Currently, the module always overwrites an existing MASK and requires either the QAB band or a raster representing unreliable pixels which the module then uses as an inverted mask. I would like to propose to leave the (cloud) masking out of the module and leave that to other modules (i.landsat8.qc, r.reclass, r.mask…).
Please find attached a diff covering the suggested changes in i.landsat8.swlst plus some message and UI cosmetics.
Nikos, if you prefer a PR on github I can create one (don`t know how you sync gtihub and svn…)?
If you agree in the proposed changes I will also check and adjust the manual accordingly…
Kind regards,
Stefan
(attachments)
i.landsat8.swlst.diff (9.65 KB)
