Apparently i.modis won't run if the current projection definition does
not have the 'datum' defined. I.e., in a location like,
g.proj -p
-PROJ_INFO-------------------------------------------------
ellps : clark66
proj : ll
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : degree
units : degrees
meters : 1.0
it will fail:
i.modis.import input=MOD11A1.A2016174.h18v04.006.2016240225941.hdf
File "/home/user/.grass7/addons/scripts/i.modis.import", line 607, in <module>
sys.exit(main())
File "/home/user/.grass7/addons/scripts/i.modis.import", line 559, in main
single(options, remove, analyze, over, outfile)
File "/home/user/.grass7/addons/scripts/i.modis.import", line 360, in single
projObj = projection()
File "/home/user/.grass7/addons/etc/i.modis/rmodislib.py", line 353, in __init__
if self.proj['datum']:
KeyError: 'datum'
Should the error message be improved, i.e. provide a clue to "switch" to
another location?
On Tue, Sep 25, 2018 at 11:40 AM Nikos Alexandris
<nik@nikosalexandris.net> wrote:
Nikos Alexandris:
>> g.proj -p
>> ellps : clark66
>> proj : ll
>> no_defs : defined
>> unit : degree
>> units : degrees
>> meters : 1.0
Markus Neteler:
>... besides error catching in i.modis, how was that location created?
The Coordinate Reference System (CRS) is identical to the
MOD11C1/MYD11C1 product as provided by NASA. In WKT as reported by
GDAL:
GEOGCS["Unknown datum based upon the Clarke 1866 ellipsoid",
DATUM["Not specified (based on Clarke 1866 spheroid)",
SPHEROID["Clarke 1866",6378206.4,294.9786982138982,
AUTHORITY["EPSG","7008"]]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]]
Hence, following NASA - MODIS. It seems that a fix in i.modis is needed.
GDAL:
GEOGCS[“Unknown datum based upon the Clarke 1866 ellipsoid”,
DATUM[“Not specified (based on Clarke 1866 spheroid)”,
SPHEROID[“Clarke 1866”,6378206.4,294.9786982138982,
AUTHORITY[“EPSG”,“7008”]]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433]]
Nikos,
Please, open a ticket for this so it doesn’t get lost in emails.
