[GRASS-dev] i.ortho.photo/lib/ref_points.c and making a REF_POINTS file
Looking for some lore from i.ortho.photo days in GRASS 6 and before...
Within i.image.2target, i.ortho.transform requires a REF_POINTS (image E, image N, photo X, photo Y) file as part of its RMS error computation, before using a CONTROL_POINTS (photo X, photo Y, photo Z, control X, control Y, control Z) file made by i.image.2target interactive GCP creation module.
the i.photo.2image module, to my understanding is from (photo X, photo Y) to (image X, image Y), i.e. we keep in the non-map units, we only find the proper coordinates of the camera within the camera absolute dimensions (i.e. mm or other). So I do not believe it is related to generating a REF_POINTS file.
anybody who extensively used these modules before?
Yann
Hi Yann,
On Mon, May 8, 2017 at 10:12 PM, Yann <dr.yann.chemin@gmail.com> wrote:
Looking for some lore from i.ortho.photo days in GRASS 6 and before…
the i.photo.2image module does generate a REF_POINTS file. This is needed to translate from sensor (mm) to image (xy, pixels) and back. The sensor is e.g. the CCD in a DSLR, e.g. for Canon EOS-1Ds the sensor would be 35.8 mm × 23.8 mm.
HTH,
Markus M
Thanks Markus,
now I can see the missing link.
Ciao,
Yann
On 09/05/2017 08:45, Markus Metz wrote:
Hi Yann,
module.
REF_POINTS file.
× 23.8 mm.
HTH,
Markus M
