[GRASS-dev] i.pansharpen and Landsat 8
Using L8 with i.pansharpen gives nodata output, is it assuming 8-bit datasets?
datasets?
Bonjour Yann.
So far all of my tests (using Landsat5, Landsat7, IKONOS, QuickBird2 and
WorldView2 imagery) indicate that you _need_ to feed the module with 8-bit
data.
For your interest, there is also a related ticket:
<https://trac.osgeo.org/grass/ticket/2048&gt;\.
My small research on it as an answer in a related question over at GIS@SE:
<http://gis.stackexchange.com/questions/39174/how-to-color-balance-false-composites-of-pan-sharpened-landsat-images-in-grass/67319#67319&gt;\.
So you better rescale, optinally color-balance before sharpening, sharpen and,
probably color-rebalance after sharpening.
Best, Nikos
datasets?
I didn't have such problems, see
http://courses.neteler.org/processing-landsat-8-data-in-grass-gis-7-rgb-composites-and-pan-sharpening/
> datasets?
Hi Markus.
I cannot confirm this :-(. I only wish am completely wrong on this. I tested
with LC81260592013137LGN01.
All bands are visible when drawn in "d.mon wx0" and they (i.e. B2, B3, B5 and
Pan) range in min=0, max=65535 (16-bit, unsigned). I MASKed the area of my
interest. I then ran
i.pansharpen ms3=B5 ms2=B3 ms1=B2 pan=B8 output=sharpen sharpen=ihs --v
All of the derived sharpen_* maps are of min=NULL, max=NULL. If I rescale them
to 8-bit, i.e.
r.rescale B2 out=B2_255 to=0,255
r.rescale B3 out=B2_255 to=0,255
r.rescale B3 out=B3_255 to=0,255
r.rescale B5 out=B5_255 to=0,255
!!:gs/B5/B8
it works fine. Both the data have a "valid" range, i.e. they are not NULLs,
and they are drawn perfectly fine on "d.mon wx0". For the records:
r.info sharpen_green -r
min=0
max=158
r.info sharpen_red -r
min=0
max=175
r.info sharpen_blue -r
min=0
max=144
Nikos
On 23/10/13 12:48, Markus Neteler wrote:
datasets?
In the first part of that tutorial, you run i.landsat.toar on the data. Could that make a difference ?
Moritz
I did not run i.landsat.toar, so data is still 16-bit, not float. Might be the difference indeed.
On 23 October 2013 18:43, Moritz Lennert <mlennert@club.worldonline.be> wrote:
datasets?
I didn’t have such problems, see
Moritz
grass-dev mailing list
grass-dev@lists.osgeo.org
>> datasets?
I (re-)tested here by using the same bands that were already converted to Top
of Canopy Reflectance (based on DOS1). The outputs are not NULLs. However, I
don't like the look of it, even after rebalancing.
G70 [ mangroves_monitoring / bengalis_island_utm_48n @LC81260592013137LGN01 ]
: ~ [12/134]
r.info -r B.ToCR.DOS1.2
min=0.0279806868991949
max=0.0887139433548827
[Raster MASK present]
: ~ [13/135]
!!:s/2/3
r.info -r B.ToCR.DOS1.3
min=0.162416309747371
max=0.826031487626996
: ~ [14/136]
!!:s/3/5
r.info -r B.ToCR.DOS1.5
min=0.12789699116205
max=1.01093695749278
: ~ [15/137]
!!:s/5/8
r.info -r B.ToCR.DOS1.8
min=0.156489372272025
max=0.839101471394332
and
for Sharp in `g.mlist rast pat=sharpen_ToCR*` ; do r.info "${Sharp}" -r ;
done
min=0
max=0
min=0
max=2
min=0
max=2
I think this is a Floating Point vs. Integers values issue here (if I recall
from the discussion in ticket #2048).
Nikos
