Here is the error message. Any thoughts or does this need a ticket?
Errors in:
/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/imagery/i.pca
In case of errors please change into the directory with error and run ‘make’.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Wed May 14 11:26:52 MST 2014
make: *** [default] Error 1
anthgradpc7:grass64_rb cmbarton$ cd /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/imagery/i.pca
anthgradpc7:i.pca cmbarton$ make
gcc -I/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/dist.x86_64-apple-darwin13.1.0/include -I/usr/local/include -g -O2 -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk -I/usr/local/include -DPACKAGE="“grassmods”" -I/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/dist.x86_64-apple-darwin13.1.0/include -o OBJ.x86_64-apple-darwin13.1.0/support.o -c support.c
support.c:66:30: warning: format string is not a string literal (potentially insecure) [-Wformat-security]
sprintf(hist.edhist[i + 1], tmpeigen);
/Developer/SDKs/MacOSX10.7.sdk/usr/include/secure/_stdio.h:50:56: note: expanded from macro ‘sprintf’
__builtin___sprintf_chk (str, 0, __darwin_obsz(str), VA_ARGS)
support.c:79:5: error: void function ‘write_history’ should not return a value [-Wreturn-type]
return G_write_history(outname, &hist);
1 warning and 1 error generated.
make: *** [OBJ.x86_64-apple-darwin13.1.0/support.o] Error 1
Michael
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
On Wed, May 14, 2014 at 8:52 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
Errors in:
support.c:79:5: error: void function 'write_history' should not return a
The function is declared void
22 static void write_history(int bands, char *outname, double
**eigmat, double *eigval)
23 {
24 int i, j;
but returns:
58 return G_write_history(outname, &hist);
59 }
Attached a proposal for fix by simply deleting the "return" (I
compared to grass70/imagery/i.pca/support.c).
Will that help?
(attachments)
i.pca.diff (400 Bytes)
That seems to have fixed it. I’ve compiled and posted GRASS 6.4.4 now. I won’t get to 6.5 before I leave, but was thinking about stopping support for that version anyway.
Michael
______________________________
C. Michael Barton
USA
Errors in:
23 {
24 int i, j;
but returns:
59 }
Will that help?
<i.pca.diff>
Michael,
On Thu, May 15, 2014 at 10:50 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
... it's not released yet.. could you please rename the file from
GRASS 6.4.4
to
GRASS 6.4 development snapshot?
I try hard to get 6.4.4RC1 tagged...
