[GRASS-dev] i.plr.py Probabilistic Label Relaxation
Dear GRASS developers,
Today I finished a first attempt at writing a GRASS script in python for probabilistic label relaxation.
The script uses a given sigfile to run i.maxlik for _every_ given signature and save the reject threshold results.
These results are used as input for the relaxation process.
This first version is v e r y slow (~ 2 min) for a 150x200 cell region and also the assignment of probabilities for 2 classes being next to each other is still very basic (1.0 if the classes are the same, 0.5 if not). But anyway, it seems to be working!
This will be part of my diploma thesis and I would like to hear your comments. Naturally I am very interested in speeding up the whole process...
This is my first self-made script for GRASS (not counting small helper-scripts), so please be kind :wink:
best regards,
Georg
(attachments)
i.plr.py (7.91 KB)
Congratulations to your first script!
Perhaps you could post an example here (ideally based on the North Carolina
data set) to facilitate testing?
best
here:
http://www.file-upload.net/download-1894443/plr_in_grass.pdf.html
you will find a small documentation including examples from the NC data set.
I also attached an updated version of the code which contained some nasty bugs - apart from being slow it should work now :wink:
best regards,
Georg
(attachments)
i.plr.py (8.29 KB)
I had hoped for some feedback... Is there generally no interest in the functionality of the script or is it the lack of speed (or something else?)
I'm interested in improving the implementation but a few hints would be useful. Here are some ideas I came up wirh:
- At the moment, probabilities are being extracted by running i.maxlik for each class. Maybe this could also be achieved by changing the i.maxlik module. However, this step should be taken out of the script to be performed seperately.
- Of course, an implementation in C would improve speed...
- As far as I know, python will load the whole image into memory - is there some python package that improves the handling of large image files?
maybe a page on the grass wiki with screenshots and examples
(using the standard sample datasets) could encourage interest?
ie a little advertising glitz.
regards,
Hamish
Thanks for the suggestion. If you are interested, I already posted a pdf with some examples. Guess I will work on a wiki-version now :wink:
bests,
Georg
done: http://grass.osgeo.org/wiki/I.plr.py
should I put a link somewhere else within the wiki?
for sure on the add-ons page entry for it, and perhaps somewhere on the Imagery page as well.
Hamish
