Markus and Glynn,
It happens that i.points won't compile on my Mac. In discussing this with
William Kyngesbury, he suggests it could be a bug missed in a recent cleanup
of vask and curses.
He also suggests modifying the i.points makefile (see below). Since I know
just enough about make files to really get into trouble, I don't want to
make this change. Can one of you take a quick look and see if this is
something that needs to be done generally or if it is something that is Mac
specific?
Thanks
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
------ Forwarded Message
From: William Kyngesburye <kyngchaos@kyngchaos.com>
Date: Mon, 22 Jan 2007 13:57:10 -0600
To: Michael Barton <michael.barton@asu.edu>
Cc: Bob Covill <bcovill@accesswave.ca>
Subject: Re: Nviz still crashing on startup with my compiled binaryRelated to the xcode project, you opined that the reason that
i.points would
not compile correctly is because of a libcurses issue. Any
suggestion as to
how to fix this? If I understood an earlier post of yours, xcode
will not go
ahead and package GRASS unless everything compiles without error.Probably a bug that needs reporting - there was the fuss a while back
about reducing unnecessary use of vask and curses, and I think curses
got removed from i.points by mistake. Though why others (non-OSX
users) haven't had this problem is a mystery.In the i.points makefile add $(CURSES) to LIBES.
------ End of Forwarded Message
