[GRASS-dev] i.rectify should test for illegal file names before launching rectification
Hello,
If you give an illegal output name to i.rectify, this is only tested after rectification. This should be done before in order to have to wait for the whole process to finish to then notice it won't work.
Moritz
Moritz Lennert wrote on 11/05/2007 04:09 PM:
Hello,
Right - I guess
G_legal_filename()
at the beginning would do the job.
Hello,
Right - I guess
G_legal_filename()
Yes, just make sure to check the given output filename + the given extension.
BTW anyone know how to give an empty extension in the tcltk gui ? On the command line I can use extension="", but in the gui I get an error because of an illegal ".
Moritz
> Right - I guess
> G_legal_filename()
extension.
Oh; you're talking about illegal *file* names (as opposed to map
names)?
I don't think that we have a check for that.
Actually, the only reliable way to check whether a filename is legal
is to actually create the file. That should also ensure that creation
doesn't fail for other reasons (permissions, read-only filesystem,
etc).
On the command line, using:
  extension=""
is the same as using just:
  extension=
The quotes are removed by the shell.
More generally, Tcl requires any quotes to go around the entire
"word", so a command line argument such as:
  text="hello world"
would need to be entered as
  "text=hello world"
or:
  {text=hello world}
in Tcl.
wait
> Right - I guess
> G_legal_filename()
extension.
names)?
No sorry, I meant map names.
  extension=""
  extension=
Thanks for the info.
  text="hello world"
  "text=hello world"
or:
  {text=hello world}
So what would be the tcltk gui equivalent of extension= or extension="" ? "Extension" is a text field to be filled in. So as a result you get a command line with extension=anything you put in the field (without any quotes. However, leaving the field empty does not work, as it is a required field. '""' doesn't work either. Would it work if the gui used curly braces around the result ? I.e. how to indicate an empty string to the gui ?
Moritz
Moritz,
I'd offer some advice, but I'm not sure I understand what you mean.
Michael
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
>> wait
>> > Right - I guess
>> > G_legal_filename()
>> extension.
> names)?
Oops; I saw "extension" and assumed filenames.
The Tcl equivalent is just:
  extension=
the gui ?
This appears to be a deficiency with the way that the GUI decides
whether to pass an option.
G_parser() can distinguish between an absent option and an option with
the empty string as its value.
If the GUI treats an empty text field as the option not being given,
then there is no way to pass an empty string as an option value.
Anything you put into the text field will be passed literally as the
option's value.
AFAICT, the only solution is to add a checkbox to each option to force
the option to be passed. I suspect that i.rectify won't be the only
module where you might want to pass the empty string as an option
value.
Note that we have a similar problem with scripts using g.parser. I.e.
there's no way to distinguish between an absent option and the empty
string as the option's value.
Moritz,
How do you reproduce the following command:
i.rectify [...] extension=
in the gui launched when running i.rectify from the menu or from the
command line without options ?
Glynn has already pointed out that this seems to be a general deficiency:
On 06/11/07 11:08, Glynn Clements wrote:
This appears to be a deficiency with the way that the GUI decides whether to pass an option.
with the empty string as its value.
If the GUI treats an empty text field as the option not being given, then there is no way to pass an empty string as an option value. Anything you put into the text field will be passed literally as the option's value.
force the option to be passed. I suspect that i.rectify won't be the
only module where you might want to pass the empty string as an
option value.
Moritz
Sorry to be dense, but an *optioal* argument *must* be present in i.rectify,
even if it is empty? This seems like a very weird situation.
To do it in TclTk, I'd do it one of two ways, depending on which execution
procedure you are using.
You could just put the whole command in quotes as a string.
set cmd "i.rectify ... extension="
[parse and run] cmd
OR
You could put the command in a list and parse it that way.
set cmdlist [list "i.rectify" "arg1" "arg2" ... "extension="]
[parse and run] cmdlist
Michael
Moritz,
option's value.
option value.
Moritz
phone: 480-965-6213
fax: 480-965-7671
It is not optional.
This is not an issue in gis.m from where you cannot call i.rectify anymore (you have to go through the georectifying tool) .You can try it by typing i.rectify at the command line. In the tcltk window that pops up, just type any bogus values into all fields except for extension. If you click on run, you will get the error message:
ERROR: Required parameter <extension> not set:
     (Output file extension (inputfile(s) + extension)).
But in my case I don't want an extension, or, said differently, I want the extension to be empty. At the command line, I can just type 'extension=', but there is no way I can give an 'empty' value to the extension parameter in the tcltk gui.
[parse and run] cmd
OR
So this means we have to change g.parser as Glynn seems to suggest, especially if this concerns other modules as well.
Moritz
Is this an error of requiring extension to be set? If so, this can be
changed in the C code of the module. This seems like the simplest solution.
Michael
It is not optional.
[parse and run] cmd
OR
Moritz
Center for Social Dynamics and Complexity
phone: 480-965-6213
fax: 480-965-7671
> It is not optional.
>> [parse and run] cmd
>> OR
No, the problem is gis.m's inability to pass the empty string as an
option's value. If you leave the text field blank, the option simply
doesn't get passed.
this would work around the immediate problem:
    if(strlen(extension) == 0)
  G_fatal_error(_("Extension required"));
or default to none,
    ext->answer = "";
    ext->required = NO;
or test for ext="none" and replace it with "".
personally, I've always just used ext='.rect' and worried more about what was
happening with the data bugs in order=3 and the -c flag.
Hamish
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
It is not optional.
[parse and run] cmd
OR
doesn't get passed.
To be totally fair it isn't gis.m's inability, but the inability of the automatically generated tcltk command gui...gis.m's menus actually do not include an entry for i.rectify as it is embedded in the georectifier (which always sets an extension).
Moritz
