[GRASS-dev] i.segment: Invalid region id -1
I am trying to (re-)segment a group of high resolution multi-spectral bands
(QuickBird2). I work with
version=7.0.svn
date=2013
revision=58327M
build_date=2013-11-29
and use a seed map (result from the Panchromatic band) and, unfortunately, I
got twice the same error message
i.segment msx out=segments_msx_t0.02 threshold=0.02 minsize=4
seed=segments_pan_t0.02 memory=10000 iterations=1000
0..5..10..15..20..25..30..35..40..45..50..55..60..65..70..75..80..85..90..95..0..5..10..15..20..25..ERROR:
The region I am working in is indeed large,
nsres: 0.6
ewres: 0.6
rows: 12384
cols: 12303
cells: 152360352
but (almost) the same extents didn't cause any errors in another, very
similar, segmentation attempt (again with QuickBird2 data). What should I look
after?
Thanks, N
version=7.0.svn
date=2013
revision=58327M
..0..5..10..15..20..25..ERROR: Invalid region id -1
nsres: 0.6
ewres: 0.6
rows: 12384
cols: 12303
cells: 152360352
look after?
I've tested this with at least three different similar cases. All work fine
without the seed map! All fail with a seed map supplied. I guess, the only
real difference is time for the processes to complete, right?
Thanks, Nikos
OK, I've just discovered that I mixed 8-bit (the Pan images) for the seed map
and 16-bit (the Multi-Spectral images). So, seed -> 8-bit, group to be
segmented -> 16-bit. Does this play a role?
Thank you, Nikos
> fine without the seed map! All fail with a seed map supplied. I guess, the
> only real difference is time for the processes to complete, right?
map and 16-bit (the Multi-Spectral images). So, seed -> 8-bit, group to be
Silly question. It does. The 8-bit seeds are not "compatible" to 16-bit data
then... :-p
N
On Tue, Dec 3, 2013 at 1:05 AM, Nikos Alexandris
No, the seed map must be integer (not more than 32 bit int), that's
the only limitation. The data to be segmented can be anything, integer
and/or floating point.
But it does not make sense to use a pan band as seeds when segmenting
the other bands. Seeds are typically the result of a previous run of
i.segment or the result of a previous classification of the same data.
Markus M
>> the only real difference is time for the processes to complete, right?
> be segmented -> 16-bit. Does this play a role?
Markus Metz:
Good to know.
Then I have inserted a small mistake in my tests/workflow. Wanted to drive
"finer objects" (from Pan) in bigger ones (based on MS). Will adjust.
Maybe we can add 1-2 sentences what a seed map is actually. What kind of
numbers per object for example.
Thanks, N
> > seed map and 16-bit (the Multi-Spectral images). So, seed -> 8-bit,
> > group to be segmented -> 16-bit. Does this play a role?
Markus Metz:
Good to know.
I guess this is because the segments are only "counted" then.
So, no problem here. All fixed. And, in most of the segmentations so far,
indeed, I used pan only (frist segmentation, then seeding a second) and fed
the derived objects with descriptive stats.
i.segment is a real working tool. It's awesome.
N
Markus Metz:
Good to know.
Not exactly. You grow stuff from seeds, in this case segments. A seeds
map defines initial segments (objects) which are then grown if
possible. Internally, a seeds map is processed just as in r.clump: all
contiguous cells with the same id will belong to the same initial
segment.
The seeds map does the opposite. You probably want to do pansharpening first.
Anyway, it does not explain why the invalid region id -1 has been
encountered, which should not happen.
Markus M
>> drive "finer objects" (from Pan) in bigger ones (based on MS).
>> Will adjust.
first.
Ha-Yey :smiley: I did (in some cases). Actually, it worked in this cases! And, of
course not in the ones I did not perform pan-sharpening.
Nikos =)
ps- Ah, as for the "-1", I can reproduce it with the data I am working on.
Care for more details (during the weekend)?
Markus M:
> >> > data.
Nikos A:
> >> Will adjust.
MM:
> first.
NA:
Just for completeness, ehm... I was too fast. So, I did use sharpenned images
only in 2 trials, however, as I can actually see in the history. The exact
same process in two different Mapsets (same Location), QuickBird2 data:
i.segment msx_hpf out=segments_msx_hpf_seeded_t0.02 threshold=0.02 minsize=4
seed=segments_pan_t0.01 memory=3000 iterations=1000
It worked in one case (repeated to be sure) and it failed in another! In the
failing case, before the ERROR message, there are multiple WARNINGS issued:
WARNING: Region consists of only one cell, nothing to update
The other 2 (out of 3) failures were simply using (wrongly) the Pan seeds to
segment the MSes. The region was set to 0.6m ns/we resolution (working in a
UTM projection).
[ Minsize set to 4 so as to be close in objects that can be tree crowns... Not
sure how much sense this makes, but it didn't hurt also as I can see in the
final classification results. I also repeated this at least once (as I can
remember) with the resolution set to 2.4 and minsize adjusted to 1 then. ]
Now, I have re-ran the "failed" one and I get this strange:
0..5..10..15..20..25..30..35..40..ERROR: Invalid region id -1489
I went after looking all of the details of the involved maps. The only
"strange" thing I can see (which I caused) is that the region is 0.6, the seed
(segments_pan_t0.01) is also 0.6 while the group of Pan-Sharpened images are
(each) of 0.60017817 (ns) x 0.60016801 (we) resolution. Is this my mistake?
The resolution(s) should be identical, right?
Thanks for shedding light, sorry for crunching time away, N
Markus M:
> >> > data.
Nikos A:
> >> Will adjust.
MM:
> first.
NA:
Different computational regions?
In the
This should not happen, a bug in the region growing algorithm.
Essentially the same like "ERROR: Invalid region id -1". Again, this
should not happen.
Yes. I guess in the process of pansharpening, the region was set to
0.6, then the resolution was adjusted to the extents (for g.region,
extents have precedence over resolution). The correct way of adjusting
the region would be to either set the region to the pan band or align
the region to the band band (g.region align=pan). Note that g.region
res=0.6 -a can introduce a pixel shift.
Can you reproduce that with sample data? Or give me chance to reproduce that?
Markus M
Markus M:
>> > >> > segmenting the other bands. Seeds are typically the result of a
>> > >> > previous run of i.segment or the result of a previous
Nikos A:
>> > >> Will adjust.
MM:
>> > first.
NA:
> images only in 2 trials, however, as I can actually see in the history.
> The exact same process in two different Mapsets (same Location),
> QuickBird2 data:
> minsize=4 seed=segments_pan_t0.01 memory=3000 iterations=1000
Absolutely. Two different, independent trials. Same Location, different
Mapsets, different regions ("physically", if I may say so, and
computationally).
> In the failing case, before the ERROR message, there are multiple WARNINGS
> issued:
should not happen.
> seed (segments_pan_t0.01) is also 0.6 while the group of Pan-Sharpened
> images are (each) of 0.60017817 (ns) x 0.60016801 (we) resolution. Is
> this my mistake? The resolution(s) should be identical, right?
I'll try.
If I can't make it with "common" data from the Spearish Location, I can try
with some publicly available High-Res images.
Nonetheless, I am convinced, for now, that the evil root was my bad choice of
setting the region using the "-a" flag. Usually, I try to keep the cell
resolutions intact, as imported. With many high resolution images I have
worked recently (IKONOS, QuickBird2, WorldView-1, WorldView-2), this is the
case. They are not exactly 0.6, 1 or 2.4 or whatever.
However, trying to make the computational region as minimal as possible, I use
very often something like "g.region zoom=Raster". This, however, has no
effect in the region's resolution. It affects only the extent. And then, I
easily fall in the trap to reset the resolution, e.g. it was set to match the
MSes and I need the Pan's, so I do "g.region res=0.6 -a".
What do you think, a short warning in the manual that "the resolution of the
computational region should be identical between subsequent segmentations that
make use of a seed map"?
Nikos
that make use of a seed map"?
Or, maybe more "aggressively", a check if the resolution of the seed map is
identical to the region's resolution at the time of the segmentation process?
N
NA:
MM:
NA:
computationally).
> > WARNINGS issued:
Is a Warning message always a bug (in the case of i.segment)?
> > the seed (segments_pan_t0.01) is also 0.6 while the group of Pan-
> > Sharpened images are (each) of 0.60017817 (ns) x 0.60016801 (we)
> > resolution. Is this my mistake? The resolution(s) should be identical,
> > right?
-- useful --
> The correct way of adjusting the region would be to either set the region
> to the pan band or align the region to the band band (g.region align=pan).
-- useful --
> Note that g.region res=0.6 -a can introduce a pixel shift.
I'll try.
I can't reproduce this anymore (with my working images) after being careful
with extent and resolution. Two examples, both worked fine:
1) Seed map (Pan), HPF-Sharpened MSes and Region: all of 0.59998996
2) Seed map (Pan), group of HPF-Sharpened MSes and Region: all of 0.60017817 x
0.60016801
However, in a completely different setup (Location, Mapsets), I can see
multiple Warnings, like above, no error though. The process completes fine and
I get to see the segments. Is this ok?
If not, could it be related with sub-sequent processing errors? For example,
like invalid classification signatures from i.cluster and failure of i.maxlik?
I use(d) fancy segments-stats (segments used as a cover, group of Multi-
Spectral images used as source for stats) like skewness, kurtosis, etc.
Nikos
