On 03/08/17 10:11, Markus Metz wrote:
On Thu, Aug 3, 2017 at 7:02 AM, Moritz Lennert <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>> wrote:
> On 02/08/17 21:43, Markus Metz wrote:
>> Hi Moritz,
>> On Wed, Aug 2, 2017 at 2:52 PM, Moritz Lennert <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be> <mailto:mlennert@club.worldonline.be>> wrote:
>> > Hi MarkusM,
>> > Working on segmentation parameter optimization with fairly large images we have stumbled upon some questions (ISTR that we've discussed this before, but I cannot find traces of that discussion). As a reminder, i.segment.uspo works by looping through a series of threshold parameter values, segmenting a series of test regions at each parameter value and then comparing the results in order to identify the "optimal" threshold.
>> > Two issues have popped up:
>> > - One approach we tried was to optimize thresholds separately for different types of morphological zones. For each type we have several polygons distributed across the image. These polygons are used as input for a mask. However, it does seem that even if most of the image is masked, open_files() takes a long time, as if it does read the entire image. Is this expected / normal ? Would it be possible to reduce the read time when most of the area is masked ?
>> You could reduce the read time by zooming to the current mask with g.region zoom=current_mask
> Yes, but this doesn't help for situations where the mask areas are distributed across the entire image, so that the region will be almost as large as the original image.
>> > - More generally: for every i.segment call, open_files() goes through the reading of the input files and, AFAIU, checks for min/max values and creates the seglib temp files (+ possibly other operations). When segmenting the same image several times just using different thresholds, it would seem that most of what open_files() does is repeated in exactly the same manner at each call. Would it be possible to cache that information somehow and to instruct i.segment to reuse that info each time it is called on the same image and region ?
>> The most time (and disk space) consuming part of open_files() is creating temporary files for the input files and the current region and the current mask. These temporary files are temporary because too many things can change between two consecutive runs of any module using the segment library. First of all, the input files could change (same name, but different cell values), then region and mask settings could change.
> Agreed, but here I'm talking about the situation where I run i.segment multiple times in a loop with exactly the same input, and only threshold value (and possibly minsize) changing. So we hoped that it would be possible to reuse the segment library files.
One problem is that the contents of the temporary files are modified at runtime and can thus not be re-used for a new run. This is in order to save disk space and memory, otherwise resource requirements would double if input and output are kept separate.
Ok, understood.
>> > Just trying to crunch larger and larger images...
>> As in, it's working but a bit slow?
> i.segment is definitely not slow compared to other similar software, but in this specific case of looping the accumulated time used in the phase of reading the input files grows to a significant duration.
Reading input can take some time, but I thought that most of the time is spent on the actual segmentation which takes substantially longer than reading the input.
Yes, sure, we were just wondering whether this might be a low-hanging fruit, but I now see it is quite the contrary.
Related to this is the question of parallel processing: we've hit upon the issue of several parallel processes all doing the same open_files() run at the beginning on the same file. Obviously this quickly leads to a severe bottleneck when you do not use a parallel file system, but we also thought that maybe the information could be shared. I now understand that this is not feasible since the info will be modified by each process.
Of course reading input maps does require some time, but I can't see a reasonable solution for creating a permanent cache of the input data without lots of sanity checks and increasing resource requirements. I see more potential in the actual segmentation part, maybe this could be further optimized.
We're always ready to test any such optimizations. But as I said, I believe GRASS GIS is already quite fast in its region growing segmentation...
Moritz
