[GRASS-dev] i.sentinel.import does not list downloaded data
I have downloaded some selected Sentinel-2 scenes using "sentinelsat" [1]:
sentinelsat -u myuser -p secret --uuid
98f00e12-3b62-4c54-8554-c4439bb1ebef --download
which downloaded as desired (since i.sentinel.download does not have a
uuid parameter I used sentinelsat):
ls -1 data/
S2A_MSIL2A_20180628T115401_N0208_R023_T29ULT_20180628T125228.zip
S2A_MSIL2A_20180628T115401_N0208_R023_T29ULU_20180628T125228.zip
S2A_MSIL2A_20180628T115401_N0208_R023_T29UMT_20180628T125228.zip
S2A_MSIL2A_20180628T115401_N0208_R023_T29UMU_20180628T125228.zip
Now trying to import these scenes, I don't get anything with
i.sentinel.import [2]
# print
i.sentinel.import -p input=data
--> nothing, should list the channels?
i.sentinel.import -p input=data pattern="B0[4|8]_10m"
--> nothing, should list the selected channels?
Does anyone know why this fails? What am I missing?
thanks,
[1] http://sentinelsat.readthedocs.io/en/stable/cli.html
[2] https://grass.osgeo.org/grass7/manuals/addons/i.sentinel.import.html
út 14. 8. 2018 v 14:58 odesílatel Markus Neteler <neteler@osgeo.org> napsal:
now possible :slight_smile:
$ i.sentinel.download settings=sentinel.txt
uuid=98f00e12-3b62-4c54-8554-c4439bb1ebef output=data
# print
This seems to work for me.
$ i.sentinel.import -p input=/tmp/sentinel
/tmp/sentinel/S2A_MSIL2A_20180628T115401_N0208_R023_T29UMU_20180628T125228.SAFE/GRANULE/L2A_T29UMU_A015750_20180628T115400/IMG_DATA/R10m/T29UMU_20180628T115401_B03_10m.jp2
0 (EPSG: 32629)
/tmp/sentinel/S2A_MSIL2A_20180628T115401_N0208_R023_T29UMU_20180628T125228.SAFE/GRANULE/L2A_T29UMU_A015750_20180628T115400/IMG_DATA/R10m/T29UMU_20180628T115401_B08_10m.jp2
0 (EPSG: 32629)
Can you try on empty data directory with fresh addons?
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Wed, Aug 15, 2018 at 11:50 AM Martin Landa <landa.martin@gmail.com> wrote:
Testing:
GRASS 7.5.svn (ireland):~ > i.sentinel.download -l
settings=~/.esa_sentinelhub uuid=98f00e12-3b62-4c54-8554-c4439bb1ebef
98f00e12-3b62-4c54-8554-c4439bb1ebef 2018-06-28T11:54:01Z 0% S2MSI2A
Works - great, thank you!!
> # print
0 (EPSG: 32629)
0 (EPSG: 32629)
# relative path
GRASS 7.5.svn (ireland):/scratch/ireland > i.sentinel.import -p input=data
# absolute path
input=/scratch/ireland/data
## ... nothing reported while the data are there:
GRASS 7.5.svn (ireland):/scratch/ireland > ls -lart data/
total 3267768
-rw-rw-r-- 1 mundialis mundialis 784858224 Aug 14 12:32
-rw-rw-r-- 1 mundialis mundialis 1037024033 Aug 14 12:35
-rw-rw-r-- 1 mundialis mundialis 955002429 Aug 14 12:51
-rw-rw-r-- 1 mundialis mundialis 569305492 Aug 14 13:33
# test with empty one:
GRASS 7.5.svn (ireland):/scratch/ireland > mkdir data2
input=/scratch/ireland/data2/
Unfortunately nothing yet...
st 15. 8. 2018 v 22:28 odesílatel Markus Neteler <neteler@osgeo.org> napsal:
total 3267768
right, that's because you downloaded Sentinel products by sentinelsat
directly and not by i.sentinel.download.
i.sentinel.download unzips downloaded archives, and i.sentinel.import
expects uncompressed data. I wanted to change this behaviour some time
ago. i.sentinel.import should read zipped archives directly. Will
change it in the next days.
Ma
Martin Landa
st 15. 8. 2018 v 23:30 odesílatel Martin Landa <landa.martin@gmail.com> napsal:
done in r73107. Testing welcome :slight_smile:
Ma
Martin Landa
Hi Martin,
On Thu, Aug 16, 2018 at 8:47 AM Martin Landa <landa.martin@gmail.com> wrote:
Truely great!
Works also with filtering in multiple (zip'ed) Sentinel-2 scenes!
data/S2A_MSIL2A_20180628T115401_N0208_R023_T29ULT_20180628T125228.SAFE/GRANULE/L2A_T29ULT_A015750_20180628T115400/IMG_DATA/R10m/T29ULT_20180628T115401_B04_10m.jp2
0 (EPSG: 32629)
data/S2A_MSIL2A_20180628T115401_N0208_R023_T29ULT_20180628T125228.SAFE/GRANULE/L2A_T29ULT_A015750_20180628T115400/IMG_DATA/R10m/T29ULT_20180628T115401_B08_10m.jp2
0 (EPSG: 32629)
data/S2A_MSIL2A_20180628T115401_N0208_R023_T29ULU_20180628T125228.SAFE/GRANULE/L2A_T29ULU_A015750_20180628T115400/IMG_DATA/R10m/T29ULU_20180628T115401_B04_10m.jp2
0 (EPSG: 32629)
data/S2A_MSIL2A_20180628T115401_N0208_R023_T29ULU_20180628T125228.SAFE/GRANULE/L2A_T29ULU_A015750_20180628T115400/IMG_DATA/R10m/T29ULU_20180628T115401_B08_10m.jp2
0 (EPSG: 32629)
data/S2A_MSIL2A_20180628T115401_N0208_R023_T29UMT_20180628T125228.SAFE/GRANULE/L2A_T29UMT_A015750_20180628T115400/IMG_DATA/R10m/T29UMT_20180628T115401_B04_10m.jp2
0 (EPSG: 32629)
data/S2A_MSIL2A_20180628T115401_N0208_R023_T29UMT_20180628T125228.SAFE/GRANULE/L2A_T29UMT_A015750_20180628T115400/IMG_DATA/R10m/T29UMT_20180628T115401_B08_10m.jp2
0 (EPSG: 32629)
data/S2A_MSIL2A_20180628T115401_N0208_R023_T29UMU_20180628T125228.SAFE/GRANULE/L2A_T29UMU_A015750_20180628T115400/IMG_DATA/R10m/T29UMU_20180628T115401_B08_10m.jp2
0 (EPSG: 32629)
data/S2A_MSIL2A_20180628T115401_N0208_R023_T29UMU_20180628T125228.SAFE/GRANULE/L2A_T29UMU_A015750_20180628T115400/IMG_DATA/R10m/T29UMU_20180628T115401_B04_10m.jp2
0 (EPSG: 32629)
Thanks a lot, looks now like the perfect tool!
PS: geobeers in Prague then! :slight_smile:
Hi Martin,
found a small glitch when a user enters a non-sensical UUID (low priority):
GRASS 7.5.svn (utm32N):~ > i.sentinel.download
uuid=b8d040e9-9466-453c-8792-5a451f0943a0_1_8A1104_20170314T104411 -l
  File "/home/mundialis/.grass7/addons/scripts/i.sentinel.download",
line 386, in <module>
    sys.exit(main())
line 358, in main
    downloader.set_uuid(options['uuid'].split(','))
line 303, in set_uuid
    for k, v in self._api.get_product_odata(uuid, full=True).items():
  File "/usr/lib/python2.7/site-packages/sentinelsat/sentinel.py",
line 383, in get_product_odata
    _check_scihub_response(response)
line 892, in _check_scihub_response
    raise api_error
sentinelsat.sentinel.SentinelAPIError: HTTP status 500 Internal Server
Error: InvalidKeyException : Invalid key
(b8d040e9-9466-453c-8792-5a451f0943a0_1_8A1104_20170314T104411) to
access Products
Could you please catch this error message?
Thanks
Hi Markus,
út 21. 8. 2018 v 12:29 odesílatel Markus Neteler <neteler@osgeo.org> napsal:
access Products
fixed in r73129. Martin
Martin Landa
