Greetings
I’m using WinGRASS6.4 and I’m having a few difficulties with language packages
I already set my language at init.bat and I my WxGui is translated wihout problems.
But, When I open i.tasscap the script description and options is not translated, and according to my grasswxpy.po it was suppose to be.
And the same happens with i.oif. It seems that wxpy.po is not being used to translate scripts but only to GUI.
Any ideas of how to solve this?
Thanks
Gilbert
On Wed, Jan 27, 2010 at 11:47 AM, Gilbert Ferrara
<gilbertferrara1974@gmail.com> wrote:
Greetings
I'm using WinGRASS6.4 and I'm having a few difficulties with language
packages
problems.
That's right.
The script messages are in the
grassmods_XX.po
files. You need to translate there (please send the the changes then
for inclusion
in SVN).
> packages
> problems.
That's right.
grassmods_XX.po
for inclusion
in SVN).
Should g.parser be updated to allow the translation domain to be
specified?
Currently, it uses "grassmods" (g.parser itself is a module), but that
means that anyone wanting to translate a custom script has to merge
their translations into the grasssmods_*.po files.
It might be useful to allow this to be overridden via e.g. an
environment variable (adding command-line options to g.parser is
tricky), so that individual scripts could use a different domain.
On Thu, Jan 28, 2010 at 3:00 PM, Glynn Clements
grassmods_XX.po
for inclusion
in SVN).
specified?
I think yes.
It would be pretty nice to separate the "main" GRASS part from user
customization also for the translations.
Sounds good to me and I volunteer to make tests then.
> specified?
I think yes.
r40727 and r40728 allow the translation domain to be specified via
GRASS_TRANSLATION_DOMAIN, e.g. (shell):
GRASS_TRANSLATION_DOMAIN=myscript
export GRASS_TRANSLATION_DOMAIN
if [ "$1" != "@ARGS_PARSED@" ] ; then
exec g.parser "$0" "$@"
fi
or (Python):
if __name__ == "__main__":
os.environ['GRASS_TRANSLATION_DOMAIN'] = 'myscript'
options, flags = grass.parser()
main()
