[GRASS-dev] IAU to wkt C code (converted from Trent Hare's Python code)
I am at the OSgeo Code Sprint in Paris, I have converted the Python script from Trent Hare to generate on the fly PROJCS and GEOCS WKTdescriptions for all IAU2000 and IAU2009.
I am now looking at inserting that info in GRASS to support these planetary projections.
Any help welcome, I am here 2 more days.
Yann
PS: GDAL is also going to insert it.
Yann Chemin
Address: 3 Toul Melin, 56400 Plumergat
Mobile: +33 (0)7 83 85 52 34
Hi Yann,
back to this topic:
Did this actually happen?
Because GRASS no longer reads local CSV files and - to my knowledge -
completely relies on GDAL/PROJ (see https://trac.osgeo.org/grass/ticket/2456).
Hence, your two CSV files iau2000.csv + iau2009.csv and no longer shipped.
Can you confirm that all works fine through GDAL (which version is
needed to have IAU support?)
thanks
Checking with Trent, will report here soon.
On May 5, 2016 7:57 PM, “Markus Neteler” <neteler@osgeo.org> wrote:
Hi Yann,
back to this topic:
thanks
OK had a time to look at
Removing the WKT files iau2000.csv & iau2009.csv will stop the wizard new location based on these IAU files to work. These files are not in GDAL yet and they are parsed by the New Location wizard on selection of the IAU-based option. Getting those files in GDAL is rather an issue as yet, I might have time to do that in the near future (i.e. coming months), but not in the coming weeks. Please could you restore those files. Thank you, Yann
On May 5, 2016 7:57 PM, "Markus Neteler" <neteler@osgeo.org> wrote:
Hi Yann,
back to this topic:
for
thanks
Yann Chemin
Well, while I could restore them the mechanism changed. AFAIK the CSV files are not read at all any more. Unavoidable to get the projection support back on stage, see the respective ticket.
Time to get them into GDAL (data/ I suppose)… unless there is a different solution possible.
