[GRASS-dev] illegal characters in filenames
Hi there,
while programming a grass module I would like to open some raster input files.
Doing it the way as it's done in the r.example I get the following messages,
(which I'd like to avoid):
Illegal filename. character </> not allowed.
GRASS_INFO_WARNING(5821,1): unable to find
[/home/andi/uni/da/prog/grassdb/metapop_test/PERMANENT/.tmp/hobbes/5821.0] in
[PERMANENT]
GRASS_INFO_WARNING(5821,2): unable to find
[/home/andi/uni/da/prog/grassdb/metapop_test/PERMANENT/.tmp/hobbes/5821.1] in
[PERMANENT]
When i open one of the raster files before in the grass-UI, I get the message
the "@" in metapop_test_rastersomething@PERMANENT is a prohibited character.
Is there a standard method (non-documented, or
not-to-be-found-elsewhere-in-the-grass-documents, by the way) of avoiding
these messages and getting grass to do what's supposed to do?
Thanks for the help!
Andi
Andreas Gros (PhD-Student)
Fieldstation Fabrikschleichach
University Wuerzburg
Glashuettenstr. 5
96181 Rauhenebrach
Tel.: +49 931 888 3079
Fax.: +49 931 888 3089
Are you talking about map names or file pathnames?
[PERMANENT]
If you are referring to file pathnames, don't pass them to
G_legal_filename(); that function is specifically for validating the
names of maps (i.e. files within the GRASS database).
The argument to G_legal_filename() needs to be an unqualified map name
(i.e. with no @mapset part). It isn't legal to use the map@mapset
syntax for an output map; output maps are always created in the
current mapset.
In most cases, modules don't need to explicitly validate map names.
For input maps, the name will have been validated when the map was
created, while output maps will have the name validated by the call to
G_open_raster_new().
